SpaceX F9 Transporter-3 - 2022-01-13 15:25UTC
Hello once again,
we have just received a confirmation of deployment of VZLUSAT-2! In about 15 minutes, it should start transmitting beacon!
I can confirm we have beacon!!! SatNOGS Network - Observation 5364408
Thanks everyone!
Very nice signals from VZLUSAT-2 over the U.S. Many decodes even though max elevation was only 26° (which is not great from my location).
No Scott, they are using a GOMSpace AX.100 TRX and Mode 5 is AX100 ASM+Golay framing.
gr_satellites has a yml file and you can try the UZ7HO 1KUNS-PF decoder.
Don’t forget the dashboard at: Grafana
Some FOSSASAT-2E’s have updated TLE’s. Still uncertainty on FOSSASAT-2E2 and FOSSASAT-2E3
FOSSASAT2E4 – 50987 Norad
2022-002D
1 50987U 22002D   22026.90572233  .00008036  00000+0  44823-3 0  9998
2 50987  97.5089  96.3918 0014998 182.9131 177.2015 15.13737523  2014
FOSSASAT2E5 – 51001 Norad
2022-002T
1 51001U 22002T   22026.90732326  .00007277  00000+0  40855-3 0  9994
2 51001  97.5106  96.3935 0014470 185.3313 174.7766 15.13543473  2019
FOSSASAT2E6 – 50991 Norad
2022-002H
1 50991U 22002H   22026.90696389  .00006996  00000+0  39249-3 0  9991
2 50991  97.5102  96.3932 0014637 184.5794 175.5306 15.13579900  2011
FOSSASAT2E1 - 50985 Norad or 50990 Norad
2022-002B
1 50985U 22002B   22026.90556357  .00006602  00000+0  36887-3 0  9993
2 50985  97.5089  96.3923 0015146 182.6856 177.4296 15.13741503  2011
I’ve changed them in DB and will be updated soon in Network too. Any suggestion for FOSSASAT-2E2 and FOSSASAT-2E3 or we should keep the same we follow now, 51028 and 51079?
VZLUSAT-2 has significantly drifted from ION TLE. I guess, this is the reason for unsuccessful decoding of frames in the past day.
Could anyone fit better TLE, or more time needed for good results?
Anyway, if it helps for fitting, we are saving I/Q dumps of observations at station 2380, feel free to use if it can be useful: Index of /share/satnogs/2380/vzlusat2/
New TLE set for VZLUSAT-2 by @EelkeVisser:
VZLUSAT-2
1 99768U          22027.90854915  .00000000  00000-0  47968-4 0    04
2 99768  97.5058  97.3462 0010792 182.2078 173.1343 15.11408347    09
@EelkeVisser thank you very much for the TLE, it looks like a very good match for now!
We used the generated TLE to estimate a new target for our ground station during this evening pass - it seems very closely aligned with object 51047 (FLOCK 4X-7) or 51049 (FLOCK 4X-9). We think one of these objects was misidentified, and it’s actually VZLUSAT-2.
Unfortunately we can’t tell those two apart yet. @fredy would it be possible to use Celestrak TLE of object 51047 for VZLUSAT-2 in SatNOGS? If it starts to drift, then we know VZLUSAT-2 is 51049. If it doesn’t, then we know VZLUSAT-2 is 51047.
No thanks, I am glad I can help a bit!
Tomorrow, I can fit my obs to the two Flock objects, and see if they fit. But are you sure these objects are new? Weren’t they published before your satellite got deployed? Might be worth a check! Space track has published 96 TLEs and there were 105 satellites on the ride. For sure we are missing a few TLEs.
From what I’ve seen, the best match for the calculated TLE at the moment is 51047, followed by 51049. Celestrak has no unidentified objects close to these two. But I guess it is still possible it’s missing completely (especially since we were deployed so late).
In the last pass we have been tracking 51047, and observed almost no Doppler shift, with both uplink and downlink working flawlessly. So either we’re that object, or close to it. We’ll see how the Doppler changes over the next couple of days.
@vzlu_team unfortunately none of them is VZLUSAT-2, those TLE sets were published days before VZLUSAT-2 deployment. As @EelkeVisser said, in space-track there are 96 objects for this launch for several days, so let’s start checking the new ones that will be published.
I suggest we continue use the TLE set @EelkeVisser has produced and update it with tomorrow fits. Connecting the satellite with one of the current TLE sets which will be updated once or twice per day may create more issues on reception than using the generated one. However I don’t expect big changes in orbit for OBJECTS 51047 and 51049, so it’s your call.
You’re right, I didn’t realize those were deployed so early. In that case let’s stick the the generated TLEs and see if space-track publishes anything new.
hi, LabSat was released yesterday from the ION according to D-Orbit tweet - https://twitter.com/D_Orbit/status/1487099560069672962. No TLE is available but maybe there is one that you suppose can be connected to this ION deployer (and maybe they would be similar enough)?
Labsat is enable and scheduled using ION TLE. @yiea thanks for the info!
@vzlu_team The 51047 is a bad fit, the doppler residu is high 2.7kHz:
The 51049 is even worse, 4.3kHz:
I have updated my previous TLE, but the difference is minor:
New TLE:
VZLUSAT-2
2 99768  97.5058  97.3462 0010792 182.2078 173.1300 15.11408564    03
# 20220126.79-20220128.92, 233 measurements, 0.026 kHz rms
Thanks for checking, maybe we were using outdated TLE for the 51047 observation yesterday.
Or maybe it fits well on one pass, but not on multiple passes over a couple of days.
Update from Dave @ USC’s DODONA team for relay to SatNOGS
we got late word yesterday that NORAD has updated our object, but still not listed it as an official number. It appears we are now way outside the ION traveling pack.
Here are the two TLE’s that we are tracking, with the one called DODONA-EST as the one that we just got from NORAD. WE thought Object Q was us, but they don’t exactly match. However I am uncertain if the one called DODONA-EST is up to date…
OBJECT Q
1 50998U 22002Q 22031.87326981 .00007301 00000-0 41743-3 0 9992
2 50998 97.4995 101.2409 0012142 164.3956 195.7652 15.12912791 2765
DODONA EST
1 88353U 22031.67584411 +.00007873 +00000+0 +44582-3 0 0093
2 88353 97.5062 101.0612 0007930 162.0940 198.0572 15.13268839 0273
I am not sure how to communicate to Fredy to get either of these to the SatNOGS operators…
Thanks so much!
Dave
