oh2uds
January 19, 2022, 10:41am
81
I can share you a long IQ file recorded by SDR sharp…
But I guess many observations in SatNogs can be used, here are a few with good signal levels;
https://network.satnogs.org/observations/5295788/
https://network.satnogs.org/observations/5295799/
5295799
5295844
5295842
5295844
5311088
5314170
Thanks
Baris DINC
OH2UDS/TA7W
fredy
January 19, 2022, 1:04pm
82
I’ve updated FOSSASATs, GRIZU-263A with the above TLE sets and EASAT-2 and HADES with the latest Delfi-PQ TLE set.
PE0SAT
January 19, 2022, 1:48pm
83
That would be fine.
Then I will use this and see what is possible.
K4KDR
January 19, 2022, 3:34pm
84
Good day.
Has anyone seen a TLE estimate for IRIS-A ?
Or, any mention of what other object it is suspected to be near?
-Scott, K4KDR
K4KDR
January 19, 2022, 3:47pm
85
Sorry - I just noticed the TLE on
https://db.satnogs.org/satellite/QTQP-6906-0761-2730-0630#data
… so will go with that for now.
However, any updates from observations appreciated!
K4KDR
January 19, 2022, 4:23pm
86
TLE on SatNogs was indeed close enough for me to find the downlink from IRIS-A, but had to adjust by hand to stay on the signal. We’re spoiled by how much easier everything is when an object’s TLE is known for certain!
db2os
January 19, 2022, 5:09pm
87
EA4GPZ
January 19, 2022, 5:19pm
88
Hi, I got this frame decoded with gr-satellites from a recording I did on launch day:
((transmitter . 2k4 FSK downlink))
pdu length = 60 bytes
pdu vector contents =
0000: 59 4d 32 56 52 5a 16 01 0d 15 18 35 f6 08 27 00
0010: 45 0e 06 00 30 0e 00 00 00 00 00 00 00 00 00 00
0020: 00 00 00 00 00 00 00 00 01 00 68 fd 0f ff 3c fc
0030: 02 00 ff ff 80 ff f6 ff 83 ff b5 ff
Do you know if this is a correct frame? The CRC-16 is not too strong, so it might be a false decode.
EA4GPZ
January 19, 2022, 5:25pm
89
Jan, does the Grizu-263A decoder in gr-satellites work for you?
PE0SAT
90
I have tried multiple observations and I am unable to decode frames with gr_satellites but also with the decoder made by UZ7HO both decoders can’t provide data.
Maybe you can share the IQ file.
PE0SAT
January 19, 2022, 5:27pm
91
No, but I am not sure if the ogg files can be used, clipping distorted etc.
Also the decoder from Andy isn’t working.
PE0SAT
January 19, 2022, 5:28pm
92
That seems to be DELFI-PQ on 436.650
EA4SG
93
Those signals look to be in the Delfi-PQ frequency. Remember that accoording to those whom were able to get signals from EASAT-2, it looks to be not in its nominal 436.666 but around 436.682KHz aprox.
db2os
January 19, 2022, 5:43pm
94
Ahhh Ok, thats indeed confusing… fingers crossed… 73s Peter
fredy
January 19, 2022, 6:04pm
95
@EA4SG Do you think we should change that in DB, put something like 436.680KHz?
EA4SG
January 19, 2022, 6:26pm
96
I have talked with EASAT-2 official staff and they told me to tell you that YES, but please change it to 436.683KHz.
Thanks and 73s
EA4GPZ
January 19, 2022, 6:46pm
97
Even though I got a decode (which may well be a false decode), I’m concerned that the decoders need to be modified. Having in mind what @oh2uds said, my decoder doesn’t do Manchester coding, and I guess Andy’s decoder doesn’t do it either, since we both prepared the decoders about a year ago with the information at hand. At first glance the CRC code parameters seem still the same, but I didn’t check them very carefully.
EA4GPZ
January 19, 2022, 8:24pm
98
@oh2uds , a look at the FM demodulated data from Grizu-263A in my recording from 2022-01-13 clearly shows that it doesn’t use Manchester encoding.
PE0SAT
January 19, 2022, 8:25pm
99
There are frames being forwarded to the database, most of them via sids, I guess all these are from the UZ7HO GRIZU soundmodem version.
"sat_id": "TZQT-5140-2201-6886-0585",
"norad_cat_id": 99488,
"transmitter": "",
"app_source": "sids",
"schema": "",
"decoded": "",
"frame": "3C594D3256525A1601130F391CB2081400220D0700370D1000200F0400240F04001F0F00001A0F1000290F5AFD75FFD4FD010000007EFFEAFFC8FF3300",
"observer": "W2RTV-FN31bq",
"timestamp": "2022-01-19T15:54:03Z",
"version": "1.3.11",
"observation_id": null,
"station_id": null,
"associated_satellites": [
"YYGN-3644-1894-9757-7814"
All SatNOGS network recordings I tried do not have enough SNR and there unable to decode the data.
fredy
January 19, 2022, 9:03pm
100
0 TBA - TO BE ASSIGNED
1 50984U 22002A 22018.64212213 .00010051 00000-0 56080-3 0 9995
2 50984 97.5056 88.2435 0014192 208.4577 151.5881 15.13666650 761
1 50985U 22002B 22018.70839976 .00008340 00000-0 46674-3 0 9990
2 50985 97.5100 88.3129 0014464 211.2400 148.7973 15.13611923 776
1 50986U 22002C 22018.91086894 .00008260 00000-0 47877-3 0 9994
2 50986 97.5071 88.4978 0009835 213.2526 146.8087 15.12401702 804
1 50987U 22002D 22018.70848446 .00008783 00000-0 49166-3 0 9994
2 50987 97.5099 88.3127 0014346 211.5860 148.4512 15.13588913 773
1 50988U 22002E 22018.97702954 .00004296 00000-0 25103-3 0 9997
2 50988 97.5023 88.5580 0009260 211.9851 148.0819 15.12387482 817
1 50989U 22002F 22018.97719996 .00004184 00000-0 24491-3 0 9997
2 50989 97.5038 88.5577 0009341 210.6932 149.3754 15.12338356 814
1 50990U 22002G 22018.70842277 .00010085 00000-0 56359-3 0 9994
2 50990 97.5064 88.3082 0014205 207.1648 152.8842 15.13610593 773
1 50991U 22002H 22018.70892370 .00008695 00000-0 48868-3 0 9994
2 50991 97.5114 88.3137 0013957 213.3863 146.6490 15.13453103 774
1 50992U 22002J 22018.97575147 .00005495 00000-0 31667-3 0 9998
2 50992 97.5083 88.5713 0010919 221.4988 138.5415 15.12756550 818
1 50993U 22002K 22018.97683395 .00001130 00000-0 68738-4 0 9996
2 50993 97.5071 88.5628 0009994 214.5179 145.5404 15.12421383 816
1 50994U 22002L 22018.97582815 .00002397 00000-0 14039-3 0 9992
2 50994 97.5105 88.5721 0011297 220.3071 139.7323 15.12719839 815
1 50995U 22002M 22018.97713474 .00003149 00000-0 18523-3 0 9998
2 50995 97.5023 88.5566 0009306 210.4811 149.5879 15.12350557 815
1 50996U 22002N 22018.97574147 .00002160 00000-0 12682-3 0 9993
2 50996 97.5094 88.5715 0011230 220.3817 139.6581 15.12746561 819
1 50997U 22002P 22018.97569838 .00002407 00000-0 14083-3 0 9996
2 50997 97.5092 88.5725 0011182 222.0207 138.0167 15.12757332 818
1 50998U 22002Q 22018.97555368 .00004254 00000-0 24565-3 0 9998
2 50998 97.5015 88.5591 0011005 208.6577 151.4051 15.12809910 810
1 50999U 22002R 22018.97555052 .00004308 00000-0 24869-3 0 9996
2 50999 97.5014 88.5590 0011003 208.4773 151.5858 15.12811153 811
1 51000U 22002S 22018.97557347 .00001973 00000-0 11597-3 0 9998
2 51000 97.5040 88.5607 0011446 212.1965 147.8569 15.12790706 816
1 51001U 22002T 22018.70907301 .00009192 00000-0 51701-3 0 9991
2 51001 97.5117 88.3139 0013803 214.1457 145.8888 15.13411002 774
1 51002U 22002U 22018.97547934 .00004816 00000-0 27735-3 0 9991
2 51002 97.5037 88.5613 0011311 210.9192 149.1374 15.12834244 815
1 51003U 22002V 22018.90929542 .00002543 00000-0 14825-3 0 9995
2 51003 97.5075 88.5066 0011122 223.7505 136.2846 15.12836761 806
1 51004U 22002W 22018.90927611 .00005725 00000-0 32886-3 0 9993
2 51004 97.5051 88.4972 0011684 214.4350 145.6125 15.12845716 808
1 51005U 22002X 22018.90923059 .00003491 00000-0 20200-3 0 9991
2 51005 97.5034 88.4968 0011313 210.6276 149.4296 15.12859491 805
1 51006U 22002Y 22018.90916907 .00003575 00000-0 20669-3 0 9998
2 51006 97.5091 88.5063 0011784 220.0551 139.9812 15.12870354 808
1 51007U 22002Z 22018.97528527 .00002503 00000-0 14580-3 0 9998
2 51007 97.5054 88.5617 0011927 214.8642 145.1809 15.12879000 817
1 51008U 22002AA 22018.97664618 .00003320 00000-0 19429-3 0 9996
2 51008 97.5068 88.5620 0010353 213.6194 146.4381 15.12491606 819
1 51009U 22002AB 22018.97525027 .00002682 00000-0 15590-3 0 9992
2 51009 97.5099 88.5720 0011944 218.7046 141.3330 15.12889343 811
1 51010U 22002AC 22018.97510442 .00003527 00000-0 20356-3 0 9994
2 51010 97.5106 88.5723 0012125 217.2734 142.7656 15.12936725 818
1 51011U 22002AD 22019.04123409 .00005741 00000-0 32886-3 0 9998
2 51011 97.5045 88.6274 0011974 212.3553 147.6944 15.12944082 829
1 51012U 22002AE 22018.97501847 .00003361 00000-0 19407-3 0 9996
2 51012 97.5085 88.5718 0012028 221.5041 138.5277 15.12955382 813
1 51013U 22002AF 22018.97709543 .00004150 00000-0 24279-3 0 9990
2 51013 97.5018 88.5572 0009150 211.3829 148.6856 15.12368187 817
1 51014U 22002AG 22018.97493071 .00006768 00000-0 38626-3 0 9995
2 51014 97.5175 88.5756 0012795 215.2519 144.7867 15.13002401 818
1 51015U 22002AH 22018.97496801 .00002220 00000-0 12939-3 0 9998
2 51015 97.5088 88.5701 0012262 215.9001 144.1407 15.12965333 819
1 51016U 22002AJ 22018.97495993 .00003098 00000-0 17907-3 0 9994
2 51016 97.5072 88.5713 0011724 223.6298 136.4007 15.12973302 817
1 51017U 22002AK 22018.97493924 .00005380 00000-0 30805-3 0 9995
2 51017 97.5055 88.5638 0012250 214.6974 145.3459 15.12981518 819
1 51018U 22002AL 22018.97493719 .00002686 00000-0 15574-3 0 9990
2 51018 97.5040 88.5633 0011896 210.6879 149.3657 15.12974365 810
1 51019U 22002AM 22018.90856128 .00010211 00000-0 57902-3 0 9995
2 51019 97.5181 88.5110 0012923 215.6076 144.4294 15.13098804 801
1 51020U 22002AN 22018.71029178 .00005217 00000-0 29862-3 0 9997
2 51020 97.5042 88.3027 0012177 212.2686 147.7802 15.13008706 774
1 51021U 22002AP 22018.71325665 .00004783 00000-0 28114-3 0 9994
2 51021 97.5085 88.3048 0008667 224.1795 135.8745 15.12124728 773
1 51022U 22002AQ 22018.71327207 .00004877 00000-0 28660-3 0 9999
2 51022 97.5064 88.3022 0008455 222.0200 138.0382 15.12120331 774
1 51023U 22002AR 22018.71027991 .00005215 00000-0 29846-3 0 9991
2 51023 97.5095 88.3112 0012412 218.6618 141.3726 15.13014678 777
1 51024U 22002AS 22018.71026188 .00002172 00000-0 12654-3 0 9997
2 51024 97.5098 88.3104 0012441 215.5193 144.5211 15.13011221 773
1 51025U 22002AT 22018.71014683 .00006843 00000-0 38966-3 0 9998
2 51025 97.5188 88.3158 0013105 215.6966 144.3390 15.13073949 771
1 51026U 22002AU 22018.71016123 .00003127 00000-0 18032-3 0 9994
2 51026 97.5059 88.3033 0012568 217.3901 142.6457 15.13047638 772
1 51027U 22002AV 22018.71013503 .00005242 00000-0 29955-3 0 9990
2 51027 97.5055 88.3042 0012471 214.5163 145.5260 15.13063535 779
1 51028U 22002AW 22018.71004957 .00002788 00000-0 16104-3 0 9998
2 51028 97.5052 88.3046 0012505 212.7388 147.3069 15.13081715 775
1 51029U 22002AX 22018.70997897 .00003258 00000-0 18740-3 0 9993
2 51029 97.5053 88.3052 0012430 211.4782 148.5707 15.13106144 771
1 51030U 22002AY 22018.97697086 .00002842 00000-0 16730-3 0 9996
2 51030 97.5069 88.5661 0009633 215.8787 144.1798 15.12395021 812
1 51031U 22002AZ 22018.70984309 .00004632 00000-0 26445-3 0 9998
2 51031 97.5141 88.3155 0013061 215.8605 144.1751 15.13152632 773
1 51032U 22002BA 22018.70957618 .00013532 00000-0 76222-3 0 9999
2 51032 97.4964 88.2989 0011319 200.6634 159.4141 15.13281003 775
1 51033U 22002BB 22018.70986762 .00006167 00000-0 35080-3 0 9995
2 51033 97.5136 88.3149 0012959 215.8571 144.1792 15.13153807 779
1 51034U 22002BC 22018.90911637 .00005412 00000-0 31068-3 0 9991
2 51034 97.5108 88.5065 0012011 216.8415 143.1992 15.12890837 800
1 51035U 22002BD 22018.71330341 .00002190 00000-0 13086-3 0 9998
2 51035 97.5091 88.3078 0008275 220.9345 139.1265 15.12101369 778
1 51036U 22002BE 22018.71330794 .00003275 00000-0 19382-3 0 9991
2 51036 97.5096 88.3062 0008740 225.4058 134.6460 15.12100690 778
1 51037U 22002BF 22018.90974257 .00005541 00000-0 31967-3 0 9992
2 51037 97.5101 88.5054 0011231 218.9646 141.0776 15.12707505 790
1 51038U 22002BG 22018.91109090 .00003352 00000-0 19714-3 0 9993
2 51038 97.5108 88.5067 0009427 224.3539 135.6937 15.12314287 809
1 51039U 22002BH 22018.97726103 .00002100 00000-0 12489-3 0 9992
2 51039 97.5103 88.5696 0009563 222.5975 137.4515 15.12309660 810
1 51040U 22002BJ 22018.71298951 .00005218 00000-0 30568-3 0 9992
2 51040 97.5080 88.3082 0008547 217.9355 142.1274 15.12201169 779
1 51041U 22002BK 22018.71302967 .00003040 00000-0 17977-3 0 9996
2 51041 97.5046 88.2984 0008725 213.0555 147.0131 15.12183526 771
1 51042U 22002BL 22018.71302347 .00002017 00000-0 12053-3 0 9992
2 51042 97.5102 88.3082 0008982 224.0694 135.9821 15.12183339 770
1 51043U 22002BM 22018.71301469 .00004726 00000-0 27732-3 0 9996
2 51043 97.5083 88.3077 0008623 219.0457 141.0152 15.12188065 772
1 51044U 22002BN 22018.71299553 .00002622 00000-0 15553-3 0 9998
2 51044 97.5035 88.2974 0008629 212.7060 147.3637 15.12191242 779
1 51045U 22002BP 22018.91140687 .00005513 00000-0 32247-3 0 9995
2 51045 97.5056 88.4932 0009281 209.5039 150.5669 15.12226402 806
1 51046U 22002BQ 22018.91134680 .00005368 00000-0 31393-3 0 9991
2 51046 97.5093 88.5043 0008861 220.7468 139.3100 15.12249747 808
1 51047U 22002BR 22018.91128913 .00005449 00000-0 31845-3 0 9996
2 51047 97.5100 88.5029 0009371 222.8465 137.2036 15.12266694 804
1 51048U 22002BS 22018.91127479 .00002005 00000-0 11963-3 0 9997
2 51048 97.5034 88.4939 0008906 214.7300 145.3350 15.12257487 800
1 51049U 22002BT 22018.71312355 .00002240 00000-0 13358-3 0 9996
2 51049 97.5045 88.3003 0008555 219.6283 140.4323 15.12149336 773
1 51050U 22002BU 22018.71323535 .00003038 00000-0 17998-3 0 9990
2 51050 97.5104 88.3096 0008551 224.5598 135.4946 15.12120235 775
1 51051U 22002BV 22018.71321164 .00004493 00000-0 26427-3 0 9990
2 51051 97.5048 88.2992 0008326 215.1272 144.9410 15.12136662 774
1 51052U 22002BW 22018.71337205 .00002320 00000-0 13851-3 0 9998
2 51052 97.5044 88.2992 0008194 218.0608 142.0045 15.12074916 775
1 51053U 22002BX 22018.64745026 .00002033 00000-0 12212-3 0 9996
2 51053 97.5011 88.2322 0007819 222.8641 137.1981 15.11995716 762
1 51054U 22002BY 22018.71357444 .00004130 00000-0 24400-3 0 9990
2 51054 97.5087 88.3055 0007972 221.6081 138.4544 15.12025492 771
1 51055U 22002BZ 22018.71339331 .00001811 00000-0 10898-3 0 9995
2 51055 97.5093 88.3064 0008515 224.3009 135.7541 15.12066021 773
1 51056U 22002CA 22018.71340728 .00002211 00000-0 13224-3 0 9999
2 51056 97.5053 88.2992 0008250 213.4819 146.5891 15.12064073 776
1 51057U 22002CB 22018.64749740 .00002461 00000-0 14709-3 0 9995
2 51057 97.5054 88.2347 0007801 217.1611 142.9081 15.11984113 769
1 51058U 22002CC 22018.64751254 .00003610 00000-0 21396-3 0 9996
2 51058 97.5070 88.2372 0007773 219.0216 141.0454 15.11986482 761
1 51059U 22002CD 22018.64756226 .00002452 00000-0 14663-3 0 9993
2 51059 97.5074 88.2379 0008042 225.3978 134.6597 15.11966340 765
1 51060U 22002CE 22018.64773294 .00001549 00000-0 94153-4 0 9998
2 51060 97.5093 88.2393 0008760 231.8395 128.2047 15.11904871 766
1 51061U 22002CF 22018.64784830 .00002972 00000-0 17735-3 0 9998
2 51061 97.5114 88.2414 0008681 233.3528 126.6905 15.11878669 762
1 51062U 22002CG 22019.63904499 .00003012 00000-0 17766-3 0 9994
2 51062 97.5081 89.2196 0009035 216.2231 143.8389 15.12285393 910
1 51063U 22002CH 22018.91109064 .00004139 00000-0 24243-3 0 9999
2 51063 97.5034 88.4918 0009278 210.3417 149.7277 15.12321327 809
1 51064U 22002CJ 22018.91112924 .00002621 00000-0 15499-3 0 9996
2 51064 97.5052 88.4940 0009410 211.2066 148.8607 15.12303679 800
1 51065U 22002CK 22019.63889481 .00004952 00000-0 28919-3 0 9996
2 51065 97.5032 89.2072 0009356 207.5078 152.5659 15.12333502 913
1 51066U 22002CL 22018.97732924 .00002461 00000-0 14581-3 0 9995
2 51066 97.5115 88.5701 0009665 223.6319 136.4148 15.12297581 816
1 51067U 22002CM 22018.64834917 .00003028 00000-0 18140-3 0 9990
2 51067 97.5046 88.2341 0007400 232.2873 127.7687 15.11726500 765
1 51068U 22002CN 22018.64845114 .00002094 00000-0 12671-3 0 9997
2 51068 97.5077 88.2369 0007735 235.0325 125.0180 15.11690513 767
1 51069U 22002CP 22018.97707026 .00004159 00000-0 24326-3 0 9997
2 51069 97.5018 88.5574 0009194 211.5274 148.5407 15.12375372 819
1 51070U 22002CQ 22018.97586282 .00004204 00000-0 24338-3 0 9992
2 51070 97.5067 88.5633 0011140 216.2931 143.7545 15.12720988 814
1 51071U 22002CR 22018.97603052 .00002810 00000-0 16424-3 0 9996
2 51071 97.5069 88.5640 0010920 217.1056 142.9421 15.12663489 814
1 51072U 22002CS 22018.97614126 .00012400 00000-0 71096-3 0 9993
2 51072 97.5067 88.5674 0010167 219.1266 140.9230 15.12676883 816
1 51073U 22002CT 22018.63934091 .00013686 00000-0 74376-3 0 9994
2 51073 97.5211 88.2605 0013287 252.6019 107.3760 15.14541461 767
1 51074U 22002CU 22018.63976129 .00005793 00000-0 31877-3 0 9992
2 51074 97.5269 88.2628 0013258 250.6199 109.3600 15.14370988 760
1 51075U 22002CV 22018.64015359 .00005889 00000-0 32498-3 0 9999
2 51075 97.5069 88.2474 0013563 249.2152 110.7627 15.14251520 765
1 51076U 22002CW 22018.64059476 .00003190 00000-0 17850-3 0 9996
2 51076 97.5068 88.2469 0013558 246.7961 113.1843 15.14100262 766
1 51077U 22002CX 22018.64069036 .00001830 00000-0 10407-3 0 9990
2 51077 97.5068 88.2465 0013629 246.7612 113.2185 15.14060305 768
1 51078U 22002CY 22018.64079709 .00001780 00000-0 10143-3 0 9990
2 51078 97.5067 88.2463 0013676 246.1630 113.8168 15.14027140 769
1 51079U 22002CZ 22018.64083694 .00001796 00000-0 10237-3 0 9990
2 51079 97.5068 88.2463 0013739 245.8958 114.0837 15.14014924 762
40 To be assigne TLE sets from spacetrack. In the next hours I’ll try to match them with the satellites we have received. Any hint/help is always welcome.
EDIT now the objects are 96.
