Also the CW signal from SONATE-2 is loud and clear!
From the team:
Live updates can be found in SONATE-2 -
EDIT:
From the team:
EDIT:
| Temporary NORAD ID | Satellite | Frequency | Notes | Deployed |
| AMATEUR UHF | ||||
| 98932 | ONDOSAT-OWL-1 | 435.000 MHz | per team | Manifested by Exolaunch |
| 98931 | ONDOSAT-OWL-2 | 435.000 MHz | per team | Manifested by Exolaunch |
| OTHER FREQUENCIES (UHF, L-Band, S-Band, X-Band) | ||||
| 98917 | RROCI-2 | 2217.000 MHz 2085.500 MHz? | Manifested by Maverick | |
| NOT IN DB WITHOUT FREQUENCIES | ||||
| VEERY-0E | - | 437.125 MHz FSK 9K6 for BYU payload/Iridium for commercial | Manifested by Exolaunch | |
| NUSAT-44 | - | 8030.000 MHz 8075.000 MHz 400.875 MHz | Manifested by Satellogic | |
| ICEYE X36 | - | S-band ~2276.000 MHz 401.250 MHz | Manifested by Exolaunch | |
| ICEYE X38 | - | S-band ~2276.000 MHz 401.250 MHz | ||
| ICEYE X37 | - | S-band ~2276.000 MHz 401.250 MHz | ||
| Lemur x4 | - | ~400.55 MHz ~402.788 | ||
| GHOST-4 | - | 400.500 MHz GFSK38k4 | Manifested by Maverick | |
| GHOST-5 | - | 400.500 MHz GFSK38k4 | Manifested by Maverick | |
| LACE-A/B | - | Uses Iridium | ||
| MBZ-Sat | - | |||
| LabSat-IOT | - | |||
| RAY | - | S-band | ||
| Xcraft-1 | - | |||
| ForgeStar 1-A | - | Uses Iridium |
Thanks for scheduling SONATE-2. Satellite is healthy. We will continue operating tomorrow. No more transmission of SONATE-2 are planned until 05.03. 12:14 UTC.
Hi. Thank you for the scheduling CONTECSat-1. We confirm that satellite is currently healthy but it was through the our partner. We are trying to track UHF. But, the registered frequency of UHF here is incorrect.
The correct frequency is 401.05 MHz.
I already upload the correct one as a suggestion.
Thanks.
Hi @raccooon,
I’ve just fixed the frequency, let’s see what we gonna receive in the future observations.
Thank you for your support and others ground stations!
We checked that got signal by waterfall, but we have an opinion that UHF modulation is GFSK not the GMSK. If you have some trouble to demodulate the signal, could you try with the GFSK?
All -4- of the PY4 sats are being decoded by 900 MHz LoRa stations, so congrats to Max and the Team behind that constellation! Here is a nice write-up about the project:
… the 1st pass in-range tonight was WAY out over the Atlantic, so I only got decodes w/ the yagi antenna connected to a Rasp-Pi running the PY4 Team’s python code. 15 good payloads were uploaded directly to their server via MQTT.
But on the westerly pass around 0710utc, my UNO-R4 got one decode via a little ground-plane antenna sized for 900 MHz and uploaded that payload to SatNogs via SIDS!
A quick recap and status update until now:
Received satellites:
We have an unknown satellite found by @KD9KCK strf observations, it is at ~400.520 MHz:
Also we have updated TLE sets from Celestrak:
HAMMER
1 70301C 24043A 24064.95712613 .00080770 00000+0 40240-2 0 00
2 70301 97.4635 190.2536 0010438 271.4874 63.4498 15.17571488 14
MH-1
1 70302C 24043B 24064.95724766 .00019579 00000+0 97306-3 0 08
2 70302 97.4673 190.2520 0010965 267.5275 68.0644 15.17672252 11
CONTECSAT-1
1 70303C 24043C 24064.95729280 -.00008147 00000+0 -42243-3 0 06
2 70303 97.4661 190.2527 0014550 293.2300 42.6124 15.16153543 12
PY4-2 AND 1
1 70304C 24043D 24064.95735762 -.00006960 00000+0 -34891-3 0 00
2 70304 97.4533 190.2585 0009220 280.6207 55.6026 15.17393819 17
VEERY-0E
1 70305C 24043E 24064.95738192 .00070905 00000+0 35639-2 0 09
2 70305 97.4682 190.2519 0011942 275.7224 60.6004 15.17249766 11
LEMUR-2-ROCINANTE
1 70306C 24043F 24064.95748262 .00203869 00000+0 10165-1 0 02
2 70306 97.4554 190.2576 0009338 276.9845 59.9155 15.17513217 14
LEMUR-2-JOHNNYTRUONG
1 70307C 24043G 24064.95772336 .00202388 00000+0 10060-1 0 01
2 70307 97.4573 190.2570 0009498 273.2206 64.9890 15.17618242 14
ORBASTRO-TR-2
1 70308C 24043H 24064.95787151 -.00001106 00000+0 -57675-4 0 06
2 70308 97.4654 190.2539 0015137 296.8193 42.1825 15.15925787 12
SONATE-2
1 70309C 24043J 24064.95799882 .00043189 00000+0 22599-2 0 01
2 70309 97.4633 190.2549 0015255 299.5135 40.1876 15.15805287 14
PY4-4 AND 3
1 70310C 24043K 24064.95810762 -.00007420 00000+0 -37222-3 0 04
2 70310 97.4667 190.2538 0011679 274.4303 65.8563 15.17345454 10
ONDOSAT-OWL-1 AND 2
1 70311C 24043L 24064.95813076 .00224164 00000+0 11785-1 0 04
2 70311 97.4612 190.2559 0015831 303.4990 36.9263 15.15569477 10
LEMUR-2-CHARLIE-ROSE
1 70312C 24043M 24064.95828238 .00106748 00000+0 55725-2 0 01
2 70312 97.4585 190.2570 0014404 301.7237 39.5347 15.15878360 19
IRIS-F1
1 70313C 24043N 24064.95841549 .00239965 00000+0 12541-1 0 08
2 70313 97.4559 190.2579 0014397 304.4665 37.5235 15.15794493 14
LEMUR-2-FELDHUS
1 70314C 24043P 24064.95853817 .00108042 00000+0 56086-2 0 04
2 70314 97.4552 190.2582 0013261 301.2883 41.3728 15.16089060 16
NUSAT-44
1 70315C 24043Q 24064.95896988 -.00013157 00000+0 -68005-3 0 00
2 70315 97.4625 190.2565 0013541 294.7595 50.2419 15.16278547 12
LYNK TOWER 5
1 70316C 24043R 24064.95972567 -.00008871 00000+0 -45924-3 0 01
2 70316 97.4611 190.2577 0013410 296.6780 52.4502 15.16222836 10
LYNK TOWER 6
1 70317C 24043S 24064.96008331 -.00009471 00000+0 -48990-3 0 05
2 70317 97.4582 190.2586 0012835 297.6780 53.4079 15.16259584 19
TIGER-7
1 70318C 24043T 24064.96031711 -.00013433 00000+0 -68125-3 0 09
2 70318 97.4585 190.2587 0011390 284.4667 67.8936 15.16971579 13
M3
1 70319C 24043U 24064.96075345 -.00014219 00000+0 -72039-3 0 03
2 70319 97.4607 190.2589 0011770 283.0473 71.6894 15.17002812 15
TIGER-8
1 70320C 24043V 24064.96157058 -.00014773 00000+0 -76177-3 0 09
2 70320 97.4618 190.2598 0012971 294.7936 64.3998 15.16370429 11
LACE-A
1 70321C 24043W 24064.96186456 -.00016760 00000+0 -86555-3 0 03
2 70321 97.4607 190.2601 0012863 296.2036 64.5962 15.16317168 17
LACE-B
1 70322C 24043X 24064.96225345 -.00017033 00000+0 -87892-3 0 04
2 70322 97.4581 190.2604 0012330 296.4945 66.4324 15.16353671 14
SENTRY
1 70323C 24043Y 24064.96310299 -.00015068 00000+0 -76439-3 0 09
2 70323 97.4575 190.2610 0011576 284.1301 83.4329 15.16959192 10
PYXIS
1 70324C 24043Z 24064.96362498 -.00019857 00000+0 -10212-2 0 04
2 70324 97.4616 190.2622 0012654 293.5426 76.8606 15.16470561 12
FIFI
1 70325C 24043AA 24064.96400808 -.00003841 00000+0 -19501-3 0 00
2 70325 97.4588 190.2620 0011951 284.6491 87.8495 15.16925611 10
ROSE
1 70326C 24043AB 24064.96436803 -.00012115 00000+0 -62395-3 0 08
2 70326 97.4583 190.2622 0012061 295.1627 79.3014 15.16422602 14
RIRI
1 70327C 24043AC 24064.96467706 -.00004817 00000+0 -24495-3 0 04
2 70327 97.4611 190.2633 0012423 285.8887 90.2555 15.16865279 18
YAM-6
1 70328C 24043AD 24064.96594905 -.00017666 00000+0 -90893-3 0 08
2 70328 97.4572 190.2631 0011693 294.2365 88.8565 15.16462839 15
LOULOU
1 70329C 24043AE 24064.96829859 -.00008281 00000+0 -42044-3 0 06
2 70329 97.4584 190.2657 0012351 284.8319 111.0780 15.16918885 18
APEX ARIES 1
1 70330C 24043AF 24064.96870600 -.00015321 00000+0 -78523-3 0 02
2 70330 97.4579 190.2656 0011785 290.9346 107.1996 15.16597368 15
OPTIMUS-2
1 70331C 24043AG 24064.96912382 -.00022852 00000+0 -11726-2 0 05
2 70331 97.4607 190.2683 0012310 292.6704 107.7367 15.16553289 12
JACKAL-02
1 70332C 24043AH 24064.96982752 -.00028660 00000+0 -14603-2 0 04
2 70332 97.4581 190.2667 0012208 286.9284 117.3245 15.16802525 13
JACKAL-01
1 70333C 24043AJ 24064.97064002 -.00029666 00000+0 -15235-2 0 04
2 70333 97.4583 190.2675 0011705 291.9497 116.7363 15.16533473 15
MESON-1 AND GLUON-1
1 70334C 24043AK 24064.97101155 -.00029431 00000+0 -15065-2 0 07
2 70334 97.4603 190.2703 0012410 291.2258 119.4812 15.16640110 19
GHOST-4
1 70335C 24043AL 24064.97139118 -.00025678 00000+0 -13107-2 0 02
2 70335 97.4602 190.2706 0012620 289.6452 123.1332 15.16734990 11
GHOST-5
1 70336C 24043AM 24064.97301155 -.00027692 00000+0 -14183-2 0 08
2 70336 97.4583 190.2693 0011871 289.8231 131.8030 15.16624713 11
LIZZIESAT-1
1 70337C 24043AN 24064.97436688 -.00013311 00000+0 -67980-3 0 06
2 70337 97.4581 190.2696 0012093 287.8140 141.2089 15.16718114 15
BRO-12
1 70338C 24043AP 24065.02224905 -.00072874 00000+0 -71934-2 0 03
2 70338 97.7490 190.1698 0008183 246.3775 82.6520 14.92074367 14
BRO-13
1 70339C 24043AQ 24065.02238447 -.00073040 00000+0 -72473-2 0 05
2 70339 97.7510 190.1689 0008714 252.3169 77.4352 14.91863854 13
HORACIO
1 70340C 24043AR 24065.02254535 -.00076999 00000+0 -78829-2 0 00
2 70340 97.7515 190.1688 0011203 282.3136 48.3040 14.90593905 10
RROCI-2
1 70341C 24043AS 24065.02268539 -.00082811 00000+0 -82244-2 0 06
2 70341 97.7423 190.1742 0007133 255.9095 75.4776 14.91840190 16
MUSAT2
1 70342C 24043AT 24065.02295391 -.00078624 00000+0 -79947-2 0 06
2 70342 97.7447 190.1731 0009325 281.9307 50.8943 14.90882141 15
PE2-SV2 (TYVAK-0262)
1 70343C 24043AU 24065.02311016 -.00083264 00000+0 -83056-2 0 02
2 70343 97.7413 190.1749 0007220 262.0146 71.6541 14.91665614 11
PE2-SV1 (TYVAK-0261)
1 70344C 24043AV 24065.02356850 -.00083510 00000+0 -82870-2 0 05
2 70344 97.7445 190.1737 0007761 253.7833 82.3365 14.91870028 14
X36
1 70345C 24043AW 24065.02396664 -.00069120 00000+0 -69287-2 0 01
2 70345 97.7432 190.1746 0007924 267.2884 70.9714 14.91460165 16
X38
1 70346C 24043AX 24065.02428262 -.00069958 00000+0 -70973-2 0 05
2 70346 97.7444 190.1744 0008933 280.3723 59.5813 14.90973520 13
X37
1 70347C 24043AY 24065.02461479 -.00069517 00000+0 -69840-2 0 05
2 70347 97.7475 190.1737 0008862 268.3115 73.4162 14.91364864 10
METHANESAT
1 70348C 24043AZ 24065.02528030 -.00073066 00000+0 -73905-2 0 04
2 70348 97.7464 190.1748 0008995 276.3532 68.9483 14.91093874 15
And here are the same TLE of the previous post changed to use DB’s temporary NORAD IDs:
MH-1
1 98934C 24043B 24064.95724766 .00019579 00000+0 97306-3 0 09
2 98934 97.4673 190.2520 0010965 267.5275 68.0644 15.17672252 12
CONTECSAT-1
1 98933C 24043C 24064.95729280 -.00008147 00000+0 -42243-3 0 05
2 98933 97.4661 190.2527 0014550 293.2300 42.6124 15.16153543 11
PY4-2
1 98955C 24043D 24064.95735762 -.00006960 00000+0 -34891-3 0 02
2 98955 97.4533 190.2585 0009220 280.6207 55.6026 15.17393819 19
PY4-1
1 98954C 24043D 24064.95735762 -.00006960 00000+0 -34891-3 0 01
2 98954 97.4533 190.2585 0009220 280.6207 55.6026 15.17393819 18
SONATE-2
1 98959C 24043J 24064.95799882 .00043189 00000+0 22599-2 0 02
2 98959 97.4633 190.2549 0015255 299.5135 40.1876 15.15805287 15
PY4-4
1 98957C 24043K 24064.95810762 -.00007420 00000+0 -37222-3 0 01
2 98957 97.4667 190.2538 0011679 274.4303 65.8563 15.17345454 17
PY4-3
1 98956C 24043K 24064.95810762 -.00007420 00000+0 -37222-3 0 00
2 98956 97.4667 190.2538 0011679 274.4303 65.8563 15.17345454 16
ONDOSAT-OWL-1
1 98932C 24043L 24064.95813076 .00224164 00000+0 11785-1 0 03
2 98932 97.4612 190.2559 0015831 303.4990 36.9263 15.15569477 19
ONDOSAT-OWL-2
1 98931C 24043L 24064.95813076 .00224164 00000+0 11785-1 0 02
2 98931 97.4612 190.2559 0015831 303.4990 36.9263 15.15569477 18
IRIS-F1
1 98930C 24043N 24064.95841549 .00239965 00000+0 12541-1 0 03
2 98930 97.4559 190.2579 0014397 304.4665 37.5235 15.15794493 19
SENTRY
1 98929C 24043Y 24064.96310299 -.00015068 00000+0 -76439-3 0 01
2 98929 97.4575 190.2610 0011576 284.1301 83.4329 15.16959192 12
PYXIS
1 98928C 24043Z 24064.96362498 -.00019857 00000+0 -10212-2 0 04
2 98928 97.4616 190.2622 0012654 293.5426 76.8606 15.16470561 12
ROSE
1 98927C 24043AB 24064.96436803 -.00012115 00000+0 -62395-3 0 05
2 98927 97.4583 190.2622 0012061 295.1627 79.3014 15.16422602 11
YAM-6
1 98926C 24043AD 24064.96594905 -.00017666 00000+0 -90893-3 0 02
2 98926 97.4572 190.2631 0011693 294.2365 88.8565 15.16462839 19
APEX ARIES 1
1 98925C 24043AF 24064.96870600 -.00015321 00000+0 -78523-3 0 02
2 98925 97.4579 190.2656 0011785 290.9346 107.1996 15.16597368 15
OPTIMUS-2
1 98924C 24043AG 24064.96912382 -.00022852 00000+0 -11726-2 0 03
2 98924 97.4607 190.2683 0012310 292.6704 107.7367 15.16553289 10
JACKAL-02
1 98923C 24043AH 24064.96982752 -.00028660 00000+0 -14603-2 0 00
2 98923 97.4581 190.2667 0012208 286.9284 117.3245 15.16802525 19
JACKAL-01
1 98922C 24043AJ 24064.97064002 -.00029666 00000+0 -15235-2 0 08
2 98922 97.4583 190.2675 0011705 291.9497 116.7363 15.16533473 19
LIZZIESAT-1
1 98920C 24043AN 24064.97436688 -.00013311 00000+0 -67980-3 0 04
2 98920 97.4581 190.2696 0012093 287.8140 141.2089 15.16718114 13
BRO-12
1 98918C 24043AP 24065.02224905 -.00072874 00000+0 -71934-2 0 07
2 98918 97.7490 190.1698 0008183 246.3775 82.6520 14.92074367 18
BRO-13
1 98919C 24043AQ 24065.02238447 -.00073040 00000+0 -72473-2 0 09
2 98919 97.7510 190.1689 0008714 252.3169 77.4352 14.91863854 17
RROCI-2
1 98917C 24043AS 24065.02268539 -.00082811 00000+0 -82244-2 0 05
2 98917 97.7423 190.1742 0007133 255.9095 75.4776 14.91840190 15
MUSAT2
1 98992C 24043AT 24065.02295391 -.00078624 00000+0 -79947-2 0 07
2 98992 97.7447 190.1731 0009325 281.9307 50.8943 14.90882141 16
1 98983C 24043AU 24065.02311016 -.00083264 00000+0 -83056-2 0 02
2 98983 97.7413 190.1749 0007220 262.0146 71.6541 14.91665614 11
1 98982C 24043AV 24065.02356850 -.00083510 00000+0 -82870-2 0 03
2 98982 97.7445 190.1737 0007761 253.7833 82.3365 14.91870028 12
METHANESAT
1 98916C 24043AZ 24065.02528030 -.00073066 00000+0 -73905-2 0 05
2 98916 97.7464 190.1748 0008995 276.3532 68.9483 14.91093874 16
TLE updates for BRO-12 and BRO-13 by @KD9KCK:
BRO-13
1 98919U 24065.02350336 .00000000 00000-0 -67575-2 0 01
2 98919 97.7567 190.1443 0010525 252.5020 83.2038 14.92019271 00
BRO-12
1 98918U 24065.02336794 .00000000 00000-0 -67063-2 0 04
2 98918 97.7548 190.0003 0010067 247.8472 87.0017 14.92298869 09
Congratulations on the Sonate-2 mission. Is the telemetry on all of the time, or only when the satellite is over the ground station? Have tried unsuccessfully several times on 2M and 70 cm but nothing so far.
Thank You,
Bob
N6RFM
Hi Bob,
as of now, Telemetry is only on over the GS. However, that might change in the future. If so we will let SATNOGS know!
Best
Clemens
DO2CR
Thanks Clemens. Will QRX in hopes of some global transmissions.
Best,
Bob
A big thanks from the team of SONATE-2 for scheduling and receiving telemetry of our satellite. Already more than 11k frames have been forwarded to the SATNOGS DB in less than 4 days of operations.
Over weekend we plan to broadcast a prerecorded image of SONATE-2 using our SSTV transmitter at 145.880 MHz. Here is the planned transmission schedule: (All times are UTC:)
Europe (East):
09.03.2024 12:55:00
10.03.2024 12:39:00
Europe (West):
09.03.2024 01:28:00
10.03.2024 02:50:00
11.03.2024 02:36:00
North America (East):
08.03.2024 19:34:00
09.03.2024 19:19:00
10.03.2024 19:05:00
North America (West):
08.03.2024 22:42:00
09.03.2024 22:29:00
10.03.2024 22:14:00
South America
09.03.2024 07:29:00
10.03.2024 17:50:00
Australia:
08.03.2024 15:38:00
09.03.2024 15:23:00
10.03.2024 15:10:00
East Asia (JP):
09.03.2024 05:05:00
10.03.2024 06:25:00
11.03.2024 06:11:00
Very nice, thanks
