SpaceX F9: Bandwagon 4 Rideshare - 2025-11-02 05:09 UTC
I started with Cevrosat Grafana, graphs from TLM data are working, but when I tried to copy the Statistics part of BDSAT-2 Grafana, which is somehow using DS_SATNOGS_DB to get stations received packets etc. I dont kow, ho make those panels working. The BDSAT-2 .json has it in the part inputs, but not in the settings/variables. I tried to setup it as variable, but with no results. Any tips to that, any tutorial to this?
BDSAT-2’s decoder uses fields like pid and ctl which are not available in Cevrosat-1’s decoder.
Therefore, just copy the panels from GRBAlpha’s dashboard. Its decoder has almost the same fields.
Also check the fields available in Cevrosat-1’s decoder here: SatNOGS DB - CEVROSAT-1
Thats misundersanding. I dont have any problems with informations decoded from satellite telemetry through decoder, this works. I am trying to make work the panel named Ground Stations Leaderboard By Observed Frames, or Ascii telemetry. It uses the variables from Satnogs db.
About CEVROSAT-1’s silence:
(…) we have proceeded to the next stage of in-orbit verification of the platform and its payload systems. During this phase, communication with the satellite may be intermittent or temporarily suspended while we analyse the collected data and evaluate system performance.
cevrosat.cz
Hi, I have suggested a change to the decoder to dl7ndr and he implemented it. He wrote, that the existing data must be re-decoded to have changes in decoder applied. Could you please do it for Cevrosat?
Done in the next minutes all the frames will be re-decoded.
We have 18 “TO BE ASSIGNED” TLE sets for the launch:
0 TBA - TO BE ASSIGNED
1 66293U 25248A   25341.68010444  .00009616  00000-0  82201-3 0  9997
2 66293  45.4094  72.5588 0004726   1.4845 358.6047 14.97924622  5329
1 66294U 25248B   25341.61242826  .00026240  00000-0  12837-2 0  9991
2 66294  45.4012  67.2022 0001580 297.6341  62.4383 15.17825879  5374
1 66295U 25248C   25341.65630200  .00031845  00000-0  14917-2 0  9991
2 66295  45.4100  66.7253 0002481  39.5321 320.5746 15.19242493  5384
1 66296U 25248D   25341.73068050  .00024579  00000-0  11809-2 0  9992
2 66296  45.4076  66.4222 0002080  25.9650 334.1340 15.18486670  5397
1 66297U 25248E   25341.63582594  .00034050  00000-0  15732-2 0  9990
2 66297  45.4067  66.5721 0007613  31.7512 328.3833 15.19667474  5387
1 66298U 25248F   25341.63941860  .00030774  00000-0  14307-2 0  9992
2 66298  45.4101  66.6056 0007046  37.1644 322.9729 15.19500879  5384
1 66299U 25248G   25341.66064270  .00031069  00000-0  14872-2 0  9992
2 66299  45.4029  66.7278 0003280  10.0586 350.0365 15.18502117  5386
1 66300U 25248H   25342.83335648 -.00010053  00000-0 -46616-3 0  9999
2 66300  45.4059  60.4723 0003009  33.7534 264.5320 15.18526675  5826
1 66301U 25248J   25342.83335648 -.00011592  00000-0 -54113-3 0  9990
2 66301  45.4028  60.4860 0002839  20.9647 265.8715 15.18432350  5826
1 66302U 25248K   25342.83335648 -.00008386  00000-0 -38349-3 0  9991
2 66302  45.4066  60.3944 0004007  39.7838 293.7954 15.18794343  5828
1 66303U 25248L   25341.72342193  .00024791  00000-0  11834-2 0  9997
2 66303  45.4041  66.3558 0003902  14.4843 345.6154 15.18703659  5401
1 66304U 25248M   25340.96903017  .00024452  00000-0  11082-2 0  9990
2 66304  45.4040  70.0178 0008605  27.3899 332.7440 15.20479992  4003
1 66305U 25248N   25341.62529389  .00026393  00000-0  11923-2 0  9991
2 66305  45.4042  66.4908 0008831  30.8322 329.3082 15.20550385  3242
1 66306U 25248P   25339.98572756  .00024949  00000-0  11356-2 0  9999
2 66306  45.4053  75.3173 0008264  20.8059 339.3163 15.20323445  5129
1 66307U 25248Q   25341.30200212  .00024919  00000-0  11355-2 0  9990
2 66307  45.4042  68.2872 0007817  28.7834 331.3482 15.20290149  5339
1 66308U 25248R   25337.50003472  .00012306  00000-0  60034-3 0  9993
2 66308  45.3978  89.0084 0003653 346.4266 275.8611 15.18396286  5899
1 66309U 25248S   25337.50003472  .00012033  00000-0  59221-3 0  9997
2 66309  45.4050  89.0839 0001748 359.1817 228.9243 15.18110574  2325
1 66312U 25248T   25325.00002315  .00071789  00000-0  34473-2 0  9992
2 66312  45.3982 155.7898 0003762 306.7887 314.9848 15.18021984  4124
There are no signal being received from CEVROSAT-1
Looking at the latest successful CEVROSAT-1 observation there is only one that could possibly match.
So for now I would suggest object 66309
