Updated TLE for SamSat-Ionosphere:
SamSat-Ionosphere
1 98786U 24326.81234101 .00000000 00000-0 00000-0 0 00008
2 98786 097.6804 191.0258 0020370 352.5818 139.5365 15.23397688000008
SamSat-Ionosphere
Yep, the beacon decoded successfully. Congratulations from our team. We are using USB in our ground station.
TLE updated in both Network and DB. Thank you @kddk!
For ZIMSAT-2, you can temporarily use TLE from the SamSat-Ionosphere:
ZIMSAT-2
1 98777U 24326.81234101 .00000000 00000-0 00000-0 0 00008
2 98777 097.6804 191.0258 0020370 352.5818 139.5365 15.23397688000008
I’m using gr satellites to decode RS75S in FM.
→ Packet from 1k2 AX25 FSK downlink
Container:
header = Container:
addresses = ListContainer:
Container:
callsign = u’WORLD’ (total 5)
ssid = Container:
ch = True
ssid = 0
extension = False
Container:
callsign = u’RS75S’ (total 5)
ssid = Container:
ch = False
ssid = 0
extension = True
control = 0x03
pid = 0xF0
info = b’WORLD \x00\x00\x0f\x00P\x06p\x06R\x00\x17\x01\x00\x002\x00\x10\x00\x0b\x00\x00\x00\x00\x00\x06\x006\x03\x00\x00\x00\x00\xef\t\x00\x00\xef\t\x00\x00\x7f\x08\x00\x00\xc0\x10p\x11`\x12\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\xa2\xd2\x16\x01’ (total 112)
By the way, the modulation is indicated as FSK.
So, you may also use the FSK High-Speed SoundModem (Ver. 0.01b).
2024-11-22 07:16:15 RS44S SSTV on 437.050
SITRO-AIS-37 (SC2325) frequency is 401.0025 ![]()
@sv2hwm is this based on observation or on the post above?
If it is from the post, I think this was a typo given the pattern among the other frequencies, maybe @sputnix can confirm if it was a typo or not.
If it comes from an observation please let me know in order to change it immediately.
Fixed! Thank you!
By the way, feel free to suggest such changes directly in DB. You can do that by getting logged in and in the satellite page in the transmitter tab you can edit the transmitters details.
ok thanks for the info.
TUSUR GO
1 98788U 24328.56348379 .00000000 00000-0 50000-4 0 06
2 98788 97.4000 194.0104 0012126 173.9730 198.3400 15.23901209 00
Colibri-S
1 98794U 24328.61335642 .00000000 00000-0 50000-4 0 08
2 98794 97.4000 194.2064 0002174 195.6622 167.2734 15.24966766 02
ArcticSat-1
1 98787U 24328.63532407 .00000000 00000-0 50000-4 0 00
2 98787 97.4000 193.8105 0012888 89.9297 59.7415 15.24848852 07
RTU MIREA1
1 98894U 24328.77011574 .00000000 00000-0 50000-4 0 01
2 98894 97.4000 193.2146 0017065 261.8573 161.8801 15.22710473 04
VIZARD-ion
1 98789U 24328.82802083 .00000000 00000-0 50000-4 0 03
2 98789 97.4000 190.7015 0002766 94.4012 16.8762 15.24799255 06
ASRTU-1
1 99130U 24099A 24328.77906250 .00032080 00000-0 13577-2 0 02
2 99130 097.3810 192.6205 0017010 28.8212 77.7663 15.23104422 09
For ZIMSAT-2 I temporarily use TLE:
ZIMSAT-2
1 98777U 24310.14375000 .00000000 00000-0 50000-4 0 00
2 98777 97.4000 174.6627 0005600 73.9500 162.9000 15.23116778 07
TUSUR-GO
1 98788U 24329.82843750 .00000000 00000-0 19681-2 0 07
2 98788 97.6804 194.6330 0012743 38.4490 67.2301 15.22942607 04
Hi Are you able to tell me where you got/downloaded this version of the sound modem for FSK AX 25 1200bd from? I have downloaded Ver 0.02b but they have all been programmed for different satellites and I’m not able to adjust.
Many thanks
