TLE’s for pocketcubes
2023-091AW
1 57322U 23091AW 23197.18220870 .00007406 00000+0 54719-3 0 9999
2 57322 97.6619 247.7128 0018878 182.6122 177.5008 15.03378093 674
2023-091AX
1 57323U 23091AX 23197.18228004 .00005744 00000+0 42584-3 0 9997
2 57323 97.6623 247.7119 0018938 182.3528 177.7611 15.03348246 673
2023-091AY
1 57324U 23091AY 23196.71643263 .00009033 00000+0 66706-3 0 9991
2 57324 97.6628 247.2505 0019060 183.4747 176.6349 15.03328152 608
2023-091AZ
1 57325U 23091AZ 23197.18232063 .00010942 00000+0 80602-3 0 9998
2 57325 97.6618 247.7127 0018979 182.1135 178.0013 15.03366632 674
2023-091BA
1 57326U 23091BA 23197.18228995 .00005682 00000+0 42131-3 0 9998
2 57326 97.6624 247.7122 0018906 182.4220 177.6917 15.03344346 514
2023-091BB
1 57327U 23091BB 23197.18224620 .00007712 00000+0 56969-3 0 9990
2 57327 97.6624 247.7115 0018945 182.3657 177.7482 15.03369254 516
fredy
July 16, 2023, 3:06pm
184
Any suggestion which object should be assigned to which satellite?
K4KDR
July 16, 2023, 8:36pm
185
Regarding the 2FSK mode that is transmitted in an alternating pattern from the StratoSat Pico sats, today I finally constructed reliable decoders on both the Arduino & GNU Radio platforms.
No doubt there is room for improvement to both efforts!
If anyone would like a GNU Radio starting point (plus test audio & I/Q files), my tweet w/ screen shots is at
https://twitter.com/scott23192/status/1680675916815425537
… and the files mentioned are at
https://www.qsl.net/k/k4kdr//grc/stratosat-fsk/
-Scott, K4KDR
rumlin
July 18, 2023, 8:41pm
186
EU1SAT:
AHMAT-1(RS41S)
It appears that this satellite is not functioning.
Is there any information about your satellite? We see no transmission 437.4 mhz from object 57173
satellite is operating, beacon off to save power
This is a recording of our satellite’s responses during a communication session from our ground station in Samara
https://network.satnogs.org/observations/7953945/
PE0SAT
August 14, 2023, 10:10pm
190
Going through a 48 hours STRF observation I found what looks to be a 9600 baud FSK signal on 436.498 MHz.
By using multiple single bursts over an eight hour period these frames seem to match object 57179 which is currently followed by PHI-DEMO
Looking at the observation, it seems the satellite only send a single frame every 2 minutes.
PE0SAT
August 15, 2023, 7:31am
192
Thanks for the information.
Using NORBY-2 TLE with this observation we get the following match
The TLE are very close to one another, and nice to know that NORBY-2 also transmits FSK AX.25
K4KDR
August 15, 2023, 3:28pm
193
Just like the original NORBY, NORBY-2 alternates (1 downlink per minute) between FSK & LoRa. Here is a LoRa downlink from 7-Aug:
… it seems that a rotation between multiple modes is becoming more and more common on satellites as the flight radios & on-board computers become more complex & add capabilities.
