Soyuz-2.1a / Fregat Baikonur launch 2021-03-22T06:07 UTC
The new TLE sets from spacetrack are now assigned to objects (except one). These are the current fits for the 33 TLE sets by using ikhnos (given that the satellites alone were 39, we still expecting more TLE sets):
Satellite Norad Follow Other Candidates Notes
UNISAT-7 OBJECT P(47946) OBJECT N(47944), OBJECT AG(47962) Started transmitting again, rejected OBJECT J(47940), OBJECT Q(47946), OBJECT R(47947), added OBJECT N(47944), OBJECT AG(47962), changed to follow ,OBJECT P(47945)
BCCSAT-1 OBJECT J(47940) No updated, continue to follow OBJECT J(47940), it doesn’t fit, but it is the closest
FEES OBJECT R(47947) No reception, continue to follow OBJECT R(47947)
DIY-1 OBJECT AH(47963) Rejected OBJECT AJ(47964), continue to follow OBJECT AH(47963)
SMOG-1 OBJECT AJ(47964) Rejected OBJECT AH(47963), continue to follow OBJECT AJ(47964)
STECCO OBJECT M(47943) OBJECT H(47939), OBJECT J(47940), OBJECT N(47944),OBJECT P(47945), OBJECT Q(47946), OBJECT R(47947) No signal received since 2021-03-24 23:55. No update
NANOSATC-BR2 OBJECT U(47950) OBJECT V(47951), OBJECT AB(47958), OBJECT AC(47958) No update
KMSL OBJECT U(47950) OBJECT V(47951), OBJECT AB(47958), OBJECT AC(47958) No update
CANYVAL-C 1U OBJECT G(47938) No reception continue to follow OBJECT G(47938)
CANYVAL-C 2U OBJECT G(47938) No reception continue to follow OBJECT G(47938)
BEESAT-5 OBJECT AB(47957) OBJECT U(47950), OBJECT AC(47958) Rejected OBJECT V, changed to OBJECT AB(47957)
BEESAT-6 OBJECT AB(47957) OBJECT U(47950), OBJECT AC(47958) Rejected OBJECT V, changed to OBJECT AB(47957)
BEESAT-7 OBJECT AC(47958) OBJECT U(47950), OBJECT AB(47957) Rejected OBJECT V, changed to OBJECT AC(47958)
BEESAT-8 OBJECT AC(47958) OBJECT U(47950), OBJECT AB(47957) Rejected OBJECT V, changed to OBJECT AC(47958)
CUBESX-SIRIUS-HSE OBJECT V(47951) OBJECT U(47950), OBJECT AC(47958) Added OBJECT U(47950), OBJECT AC(47958)
CUBESX-HSE OBJECT W(47952) OBJECT X(47953), OBJECT K(47941), OBJECT AD(47959) No update
ORBICRAFT-ZORKIY OBJECT AE(47960) OBJECT Y(47954), OBJECT AF(47961) Rejected OBJECT Z(47955), changed to OBJECT AE(47960)
SIMBA OBJECT W(47952) OBJECT X(47953), OBJECT K(47941), OBJECT AD(47959) No update
GRBALPHA OBJECT W(47952) OBJECT V(47951), OBJECT X(47953), OBJECT G(47938), OBJECT K(47941), OBJECT AD(47959) Added OBJECT G(47938)
CHALLENGEONE OBJECT AA(47956) No update
KSU-CUBESAT OBJECT AF(47961) OBJECT AE(47960), OBJECT Y(47954) No update
Results for UNISAT-7, SMOG-1 and ORBICRAFT-ZORKIY are also confirmed by strf observations of @PE0SAT.
