SONATE-2: SSTV + Digipeater
:CQ :SONATE-2 - Greetings from space
1:Fm DL7NDR To APDW17 Via DP0SNX* [17:06:39R] [±-]
=/5s&?PQ#-yBbW73 fm Daniel @JN48ap via SONATE-2
:slightly_smiling_face:
Jomjom79
Thank you very much!
I missed the way better pass before. This was only about 15° elevation.
I’ve put up a dashboard for Sonate-2 digipeater in a rush.
It’s work in progress.
Are demodded packets ever relayed from SatNogs to APRS-IS?
To my knowledge, there is no link between SatNOGS and APRS-IS.
202408021700
2024-08-02 17:01UTC SONATE-2 Over Brazil
Interesting, Dubai’s Palm Jebel Ali and at the top tip Palm Jumeirah.
Seems they forgot to update their SSTV schedule.
00:14utc
202408030021
Thats the extent of what i got when it started transmitting over the Czech Republic.
Its either a different picture or its corrupted. Had to manually start decoding as the signal strength was so low it would not auto detect. I assumed it was Martin M1 as that is what they have been sending in the past.
Probably not worth staying up all night for but hey. You have to try… :slightly_smiling_face:
Jomjom79
Edit: It was corrupted. Same signal with RX-SSTV that actually managed to auto detect it.
2024-08-03_02.39.31
Still not worth staying up all night for :smile:
2024-08-03 13:13 UTC
2024-08-03 13.13utc SONATE-2 - DL7NDR
It barely even registered above the noise floor here…
Hopeful for the next pass (Max 45 degree elevation)
If its even transmitting that far away from mainland Europe.
Jomjom79
14:48utc 03/08/24
2024-08-03_16.57.13
Its almost worse than last night :slightly_smiling_face:
Jomjom79
SONATE-2 at 16:44UTC over Brazil
Italy very visible !!!
73’s de PU4ELT
With a little help from K4KDR routing the wav file replay audio to QSSTV.
SONATE-2 16:25UTC over Brazil
73’s de PU4ELT
2024-08-05 01:14 UTC
2024-08-05 01.14utc SONATE-2 - DL7NDR
(max. ev.: 38°, northbound)
Digipeater active from 9th (Friday) 15:00 UTC to 11th (Sunday) 23:00 UTC.
Please contribute data for dashboard.
This is Dubai
Digipeater is up. EOT 18/08/2024 23:00 UTC
Jomjom79
Digipeater active from 23/08/2024 15:00UTC - 25/08/2024 23:00UTC.
Jomjom79
Next SSTV transmissions scheduled from August 30th 17:07 UTC to September 2nd 10:35 UTC.
Two images are transmitted sequentially at these times.”
SONATE-2 2024-08-30 17:50UTC
At 5.8 degrees elevation relative to my QTH (I’m almost sure that the satellite sent 2 images but due to the mountains to the west I didn’t receive)
73’s de PU4ELT :brazil: !!
