Update to SatNOGS Ansible 202607171639 failes for my station 858.
After the update I get this:
TASK [docker_engine : Start Docker Compose application] ************************
failed: [ansible] (item=None) => {"censored": "the output has been hidden due to the fact that 'no_log: true' was specified for this result", "changed": true}
fatal: [ansible]: FAILED! => {"censored": "the output has been hidden due to the fact that 'no_log: true' was specified for this result", "changed": true}
PLAY RECAP *********************************************************************
ansible : ok=1 changed=0 unreachable=0 failed=1 skipped=0 rescued=0 ignored=0
If I try to re-start with sudo docker restart satnogs_satnogs-client I get:
Error response from daemon: Cannot restart container satnogs_satnogs-client: error gathering device information while adding custom device "/dev/ttyUSB0": no such file or directory
So my station is dead…
