[Solved] Restrict station usage
Hi all,
Is it possible to restrict the use of the station since it was designed with a specific band pass filter (137 - 138 MHz : NOAA) via frequencies range or norad id ?
Hello!
You can use an antenna on the network that could be restricted only for those frequencies.
I just added a Turnstile with 137-138 range and you can select it for your station. Disregard the antenna type (turnstile) as it is purely informational for now.
Thank you. I will modify the station settings.
