Today, gpredict woke up showing only satellites in one of the ‘modules’ I defined. The other modules have their normal tabs, but clicking on them shows an empty map. I checked the last log and found
gtk_sat_module_load_sats: Failed to get list of satellites (Key file does not have group “GLOBAL”)
6 times, just the number of missing ‘modules’…
This has been working flawlessly for weeks now. I did not change/edit/update anything yesterday or today.
I couldn’t find references to what group “GLOBAL” means either.
I reinstalled gpredict to be sure. That doesn’t change anything though.
What does that mean?
Update I just checked the 6 files in .config/Gpredict/modules and indeed, their contents was modified to:
[LIST]
SORT_COLUMN=0
SORT_ORDER=0
The one that works has all its data intact.
I’ve no idea what did this! Do I have to worry about backing up these files too?
