Please excuse the ticket format, I am just trying to be concise and clear:
Objective: Send IIO register level commands via UDP to zedboard; SoapyADRV9361 provides this functionality for the ADRV9361 but I am using a zedboard.
Work thus far:
Installed SoapySDR
Compiled & installed SoapyADRV9361 on host and client per the instructions on github:
Problem:
I run “SoapySDRUtil --probe” to test connectivity from the client linux PC to the server zedboard and just local to the zedboard. The output is the same error:
“Error find ADRV: Unable to receive the command response
[ERROR] ADRV9361 Soapy driver could not be found”
I expect some issues as the zedboard is not and ADRV9361, but I expected soapy to at least find the AD9361 on this board, similar to IIO_attr -S does. IIO_attr -S does find the AD9361.
Ultimately, I am just trying to broadcast IIO over UDP. Are there any known ways to do this for a general case of the AD9361? If not, is it possible to adapt soapyADRV9361 for the zedboard?
