rtl_test this will test the connection and if 2.048e6 sample rate is possible
pi@raspberrypi:~ $ rtl_test
Found 1 device(s):
0: Realtek, RTL2838UHIDIR, SN: 00000003
[R82XX] PLL not locked!
Sampling at 2048000 S/s.
Info: This tool will continuously read from the device, and report if
samples get lost. If you observe no further output, everything is fine.
Reading samples in async mode…
Allocating 15 zero-copy buffers
lost at least 40 bytes
SoapySDRUtil --info this will show if all the Soapy 0.7 drivers are installed.
Lib Version: v0.7.2-2
API Version: v0.7.1
ABI Version: v0.7
Install root: /usr
Search path: /usr/lib/arm-linux-gnueabihf/SoapySDR/modules0.7
Search path: /usr/local/lib/arm-linux-gnueabihf/SoapySDR/modules0.7 (missing)
Search path: /usr/local/lib/SoapySDR/modules0.7 (missing)
Module found: /usr/lib/arm-linux-gnueabihf/SoapySDR/modules0.7/libHackRFSupport.so (0.3.3)
Module found: /usr/lib/arm-linux-gnueabihf/SoapySDR/modules0.7/libLMS7Support.so (20.10.0)
Module found: /usr/lib/arm-linux-gnueabihf/SoapySDR/modules0.7/libRedPitaya.so (0.1.1)
Module found: /usr/lib/arm-linux-gnueabihf/SoapySDR/modules0.7/libairspySupport.so (0.1.2)
Module found: /usr/lib/arm-linux-gnueabihf/SoapySDR/modules0.7/libaudioSupport.so (0.1.1)
Module found: /usr/lib/arm-linux-gnueabihf/SoapySDR/modules0.7/libbladeRFSupport.so (0.4.1)
Module found: /usr/lib/arm-linux-gnueabihf/SoapySDR/modules0.7/libmiriSupport.so (0.2.5)
Module found: /usr/lib/arm-linux-gnueabihf/SoapySDR/modules0.7/libosmosdrSupport.so (0.2.5)
Module found: /usr/lib/arm-linux-gnueabihf/SoapySDR/modules0.7/libremoteSupport.so (0.5.2)
Module found: /usr/lib/arm-linux-gnueabihf/SoapySDR/modules0.7/librfspaceSupport.so (0.2.5)
Module found: /usr/lib/arm-linux-gnueabihf/SoapySDR/modules0.7/librtlsdrSupport.so (0.3.2)
Module found: /usr/lib/arm-linux-gnueabihf/SoapySDR/modules0.7/libuhdSupport.so (0.4.1)
Available factories… airspy, audio, bladerf, hackrf, lime, miri, osmosdr, redpitaya, remote, rfspace, rtlsdr, uhd
Available converters…
- CF32 → [CF32, CS16, CS8, CU16, CU8]
- CS16 → [CF32, CS16, CS8, CU16, CU8]
- CS32 → [CS32]
- CS8 → [CF32, CS16, CS8, CU16, CU8]
- CU16 → [CF32, CS16, CS8]
- CU8 → [CF32, CS16, CS8]
- F32 → [F32, S16, S8, U16, U8]
- S16 → [F32, S16, S8, U16, U8]
- S32 → [S32]
- S8 → [F32, S16, S8, U16, U8]
- U16 → [F32, S16, S8]
- U8 → [F32, S16, S8]
SoapySDRUtil --probe="driver=rtlsdr" if the RTL-SDR can be found and contacted.
Probe device driver=rtlsdr
[INFO] Opening Generic RTL2832U OEM :: 00000003…
– Device identification
driver=RTLSDR
hardware=R820T
index=0
origin=GitHub - pothosware/SoapyRTLSDR: SoapySDR RTL-SDR Support Module
– Peripheral summary
Channels: 1 Rx, 0 Tx
Timestamps: YES
Time sources: sw_ticks
Other Settings:
* Bias Tee - RTL-SDR Blog V.3 Bias-Tee Mode
[key=biastee, default=false, type=bool]
– RX Channel 0
Full-duplex: NO
Supports AGC: YES
Stream args:
Antennas: RX
Full gain range: [0, 49.6] dB
RF freq range: [24, 1764] MHz
Filter bandwidths: [0, 8] MHz
ls -l ls -l /etc/modprobe.d/ to see if the RTL-SDR blacklisted config is in place
ls: cannot access ‘ls’: No such file or directory
/etc/modprobe.d/:
total 16
-rw-r–r-- 1 root root 17 Feb 24 2022 blacklist-8192cu.conf
-rw-r–r-- 1 root root 67 Jan 5 00:51 blacklist-ansible.conf
-rw-r–r-- 1 root root 19 Feb 24 2022 blacklist-rtl8xxxu.conf
-rw-r–r-- 1 root root 86 Jan 9 2016 libhackrf0.conf
ls -l /etc/udev/rules.d/ to see if the RTL-SDR udev device config is in place.
total 8
-rw-r–r-- 1 root root 459 Jan 5 00:50 64-limesuite.rules
-rw-r–r-- 1 root root 1883 Feb 24 2022 99-com.rules
