Hello,
In the upcoming pass view, many times (~70%) when I right click on a satellite and select “Show Next Pass”, the pass that is shown is actually the one after the next pass. Instead of being in 5 minutes it may be in 5 hours.
In the screenshot, you can see the pass being displayed is after the upcoming pass in the list for COSMOS 2428.
I am running Gpredict v2.2.1 on Windows.
Thank you.
The list of future passes will only include passes that have a minimum elevation above the threshold set in the Preferences -> Predict -> Minimum elevation. If you set it to 0 or 1 degree, the list will show all the passes.
I see this issue is related to my other post. I’ll use the workaround I mentioned there.
