If you type SoapySDRUtil --info it will list of available plugins and how they are selected (look under factories). On my computer I get the following output:
## Soapy SDR -- the SDR abstraction library ##
Lib Version: v0.7.1-g5838bc91
API Version: v0.7.1
ABI Version: v0.7
Install root: /data/sdr/runtime
Search path: /data/sdr/runtime/lib/SoapySDR/modules0.7
Module found: /data/sdr/runtime/lib/SoapySDR/modules0.7/libHackRFSupport.so (0.3.3-3c514ce)
Module found: /data/sdr/runtime/lib/SoapySDR/modules0.7/libLMS7Support.so (19.04.0-abf82140)
Module found: /data/sdr/runtime/lib/SoapySDR/modules0.7/libPlutoSDRSupport.so (0.2.0-e28e4f5)
Module found: /data/sdr/runtime/lib/SoapySDR/modules0.7/libRedPitaya.so (0.1.1-3d576f8)
Module found: /data/sdr/runtime/lib/SoapySDR/modules0.7/libairspySupport.so (0.1.2-99756be)
Module found: /data/sdr/runtime/lib/SoapySDR/modules0.7/libairspyhfSupport.so (0.1.1-a76abd9)
Module found: /data/sdr/runtime/lib/SoapySDR/modules0.7/libbladeRFSupport.so (0.4.1-1c1e8aa)
Module found: /data/sdr/runtime/lib/SoapySDR/modules0.7/libremoteSupport.so (0.5.1-0a7cb58)
Module found: /data/sdr/runtime/lib/SoapySDR/modules0.7/librtlsdrSupport.so (0.3.1-5c5d950)
Module found: /data/sdr/runtime/lib/SoapySDR/modules0.7/libsdrPlaySupport.so (0.3.0-14ec39e)
Module found: /data/sdr/runtime/lib/SoapySDR/modules0.7/libuhdSupport.so (0.3.6-7371e68)
Available factories... airspy, airspyhf, bladerf, hackrf, lime, plutosdr, redpitaya, remote, rtlsdr, sdrplay, uhd
Available converters...
- CF32 -> [CF32, CS16, CS8, CU16, CU8]
- CS16 -> [CF32, CS16, CS8, CU16, CU8]
- CS32 -> [CS32]
- CS8 -> [CF32, CS16, CS8, CU16, CU8]
- CU16 -> [CF32, CS16, CS8]
- CU8 -> [CF32, CS16, CS8]
- F32 -> [F32, S16, S8, U16, U8]
- S16 -> [F32, S16, S8, U16, U8]
- S32 -> [S32]
- S8 -> [F32, S16, S8, U16, U8]
- U16 -> [F32, S16, S8]
- U8 -> [F32, S16, S8]
So, yes, driver=lime seems to be the correct option.
