I have setup my satnogs-client in a docker contained following these instructions - https://github.com/kng/satnogs-client-docker/blob/main/lsf/LSF-GUIDE.md.
So far so good, it all seems to work fine with rtlsdr.
I now want to add sdrplay drivers to the image. The aforementioned instructions provide a way to do that, which include using an image from librespace/satnogs-client:lsf-addons.
However it seems the lst-addons tag does not exist in the librespace Docker registry - https://registry.hub.docker.com/r/librespace/satnogs-client/tags.
Can anyone advise where I can find this missing tag, or of another approach to add sdrplay?
the inofficial addons is purely maintained by me, not sure how it will be in the future. my hub images and the image tag as seen in the compose
building them adds the benefit of having latest updates for system packages and the repos built, so can be worth the time.
I also don’t update the images on dockerhub regularly, this is manual for now.
Hi, do you plan to update the lsf-addons image in the near future? I am using it (RSP-1A SDR) and would be very grateful if you have some time to do so. Also, I would help with it if I may.
How do you add the SDRPlay API in the image? The only way I know to install it is by running the installation provided by the vendor, but I don’t know how this could be integrated into the container build…
I update the images from time to time, I should really get into the automated builds but haven’t investigated that enough. The build can be done locally as well, so I’m not too worried (:
The install is located in the Dockerfile and is a bit customized.
Openwebrx does it in a different way.
