So i’ve finally got another Observation to complete.
After Running “docker restart satnogs_satnogs-client satnogs_sdrplay”
I was able to get an Observation to complete with an uploaded waterfall.
Just not sure why the “satnogs_sdrplay” needed to be restarted after Rebooting.
pi@Satnogs1920:~ $ docker restart satnogs_satnogs-client satnogs_sdrplay
satnogs_sdrplay
pi@Satnogs1920:~ $ docker exec -ti satnogs_satnogs-client SoapySDRUtil --probe
Probe device
[ERROR] avahi_client_new() failed: Daemon not running
RtApiPulse::DeviceInfo pa_context_connect() failed: Connection refused
[INFO] [UHD] linux; GNU C++ version 12.2.0; Boost_107400; UHD_4.3.0.0+ds1-5
ALSA lib confmisc.c:855:(parse_card) cannot find card ‘0’
ALSA lib conf.c:5180:(_snd_config_evaluate) function snd_func_card_inum returned error: No such file or directory
ALSA lib confmisc.c:422:(snd_func_concat) error evaluating strings
ALSA lib conf.c:5180:(_snd_config_evaluate) function snd_func_concat returned error: No such file or directory
ALSA lib confmisc.c:1334:(snd_func_refer) error evaluating name
ALSA lib conf.c:5180:(_snd_config_evaluate) function snd_func_refer returned error: No such file or directory
ALSA lib conf.c:5703:(snd_config_expand) Evaluate error: No such file or directory
ALSA lib control.c:1528:(snd_ctl_open_noupdate) Invalid CTL default
ERROR: Unable to create Avahi DNS-SD client :Daemon not running
[WARNING] Unable to scan ip: -26
[INFO] devIdx: 0
[INFO] SerNo: 1702026B00
[INFO] hwVer: 2
[INFO] rspDuoMode: 0
[INFO] tuner: 1
[INFO] rspDuoSampleFreq: 0.000000
– Device identification
driver=SDRplay
hardware=RSP2
sdrplay_api_api_version=3.150000
sdrplay_api_hw_version=2
– Peripheral summary
Channels: 1 Rx, 0 Tx
Timestamps: NO
Other Settings:
* RF Gain Select - RF Gain Select
[key=rfgain_sel, default=4, type=string, options=(0, 1, 2, 3, 4, 5, 6, 7, 8)]
* IQ Correction - IQ Correction Control
[key=iqcorr_ctrl, default=true, type=bool]
* AGC Setpoint - AGC Setpoint (dBfs)
[key=agc_setpoint, default=-30, type=int, range=[-60, 0]]
* ExtRef Enable - External Reference Control
[key=extref_ctrl, default=true, type=bool]
* BiasT Enable - BiasT Control
[key=biasT_ctrl, default=true, type=bool]
* RfNotch Enable - RF Notch Filter Control
[key=rfnotch_ctrl, default=true, type=bool]
– RX Channel 0
Full-duplex: NO
Supports AGC: YES
Stream formats: CS16, CF32
Native format: CS16 [full-scale=32767]
Antennas: Antenna A, Antenna B, Hi-Z
Corrections: DC removal
Full gain range: [0, 47] dB
IFGR gain range: [20, 59] dB
RFGR gain range: [0, 8] dB
Full freq range: [0.001, 2000] MHz
RF freq range: [0.001, 2000] MHz
CORR freq range: MHz
Sample rates: 0.0625, 0.096, 0.125, 0.192, 0.25, 0.384, 0.5, 0.768, 1, [2, 10.66] MSps
Filter bandwidths: 0.2, 0.3, 0.6, 1.536, 5, 6, 7, 8 MHz
