Hi!
I am building a station using a SDRPlay RSPdx (https://www.sdrplay.com/rspdx/). It has three antenna inputs and a single tuner. Antenna inputs can be selected by software. Here’s the info I get from SoapySDR:
-- Device identification
driver=SDRplay
hardware=RSPdx
sdrplay_api_api_version=3.150000
sdrplay_api_hw_version=4
-- Peripheral summary
Channels: 1 Rx, 0 Tx
Timestamps: NO
Other Settings:
* RF Gain Select - RF Gain Select
[key=rfgain_sel, default=4, type=string, options=(0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27)]
* IQ Correction - IQ Correction Control
[key=iqcorr_ctrl, default=true, type=bool]
* AGC Setpoint - AGC Setpoint (dBfs)
[key=agc_setpoint, default=-30, type=int, range=[-60, 0]]
* BiasT Enable - BiasT Control
[key=biasT_ctrl, default=true, type=bool]
* RfNotch Enable - RF Notch Filter Control
[key=rfnotch_ctrl, default=true, type=bool]
* DabNotch Enable - DAB Notch Filter Control
[key=dabnotch_ctrl, default=true, type=bool]
* HDR Enable - RSPdx HDR Control
[key=hdr_ctrl, default=true, type=bool]
-- RX Channel 0
Full-duplex: YES
Supports AGC: YES
Stream formats: CS16, CF32
Native format: CS16 [full-scale=32767]
Antennas: Antenna A, Antenna B, Antenna C
Corrections: DC removal
Full gain range: [0, 66] dB
IFGR gain range: [20, 59] dB
RFGR gain range: [0, 27] dB
Full freq range: [0.001, 2000] MHz
RF freq range: [0.001, 2000] MHz
CORR freq range: MHz
Sample rates: 0.0625, 0.096, 0.125, 0.192, 0.25, 0.384, 0.5, 0.768, 1, [2, 10.66] MSps
Filter bandwidths: 0.2, 0.3, 0.6, 1.536, 5, 6, 7, 8 MHz
Question: Can I configure satnogs client to use different input for each band (VHF, UHF) by specifying two different SATNOGS_ANTENNA values, one for each band?
