Been playing around. Now getting the following errors… HELP!!!
In file included from C:\Users\jbandy\Downloads\satnogs-rotator-firmware-master\satnogs-rotator-firmware-master\stepper_motor_controller\stepper_motor_controller.ino:9:0:
sketch\tc74.h: In member function ‘int8_t tc74::get_temp()’:
sketch\tc74.h:35:32: warning: ISO C++ says that these are ambiguous, even though the worst conversion for the first is better than the worst conversion for the second:
Wire.requestFrom(_id, 1);
In file included from C:\Users\jbandy\Downloads\satnogs-rotator-firmware-master\satnogs-rotator-firmware-master\stepper_motor_controller\stepper_motor_controller.ino:2:0:
C:\Users\jbandy\Documents\Arduino\libraries\Wire-master/Wire.h:69:13: note: candidate 1: uint8_t TwoWire::requestFrom(int, int)
uint8_t requestFrom(int, int);
C:\Users\jbandy\Documents\Arduino\libraries\Wire-master/Wire.h:67:13: note: candidate 2: uint8_t TwoWire::requestFrom(uint8_t, uint8_t)
uint8_t requestFrom(uint8_t, uint8_t);
sketch\tc74.h: In member function ‘int8_t tc74::get_status()’:
sketch\tc74.h:48:32: warning: ISO C++ says that these are ambiguous, even though the worst conversion for the first is better than the worst conversion for the second:
libraries\AccelStepper\AccelStepper.cpp.o (symbol from plugin): In function `AccelStepper::step(long)’:
(.text+0x0): multiple definition of `AccelStepper::step(long)’
sketch\AccelStepper.cpp.o (symbol from plugin):(.text+0x0): first defined here
(.text+0x0): multiple definition of `AccelStepper::step6(long)’
(.text+0x0): multiple definition of `AccelStepper::step8(long)’
(.text+0x0): multiple definition of `AccelStepper::setOutputPins(unsigned char)’
(.text+0x0): multiple definition of `AccelStepper::step1(long)’
(.text+0x0): multiple definition of `AccelStepper::step0(long)’
(.text+0x0): multiple definition of `AccelStepper::step2(long)’
(.text+0x0): multiple definition of `AccelStepper::step3(long)’
(.text+0x0): multiple definition of `AccelStepper::step4(long)’
(.text+0x0): multiple definition of `AccelStepper::disableOutputs()’
(.text+0x0): multiple definition of `AccelStepper::enableOutputs()’
(.text+0x0): multiple definition of `AccelStepper::runSpeed()’
(.text+0x0): multiple definition of `AccelStepper::run()’
(.text+0x0): multiple definition of `AccelStepper::setSpeed(float)’
(.text+0x0): multiple definition of `AccelStepper::setEnablePin(unsigned char)’
(.text+0x0): multiple definition of `AccelStepper::isRunning()’
(.text+0x0): multiple definition of `AccelStepper::distanceToGo()’
(.text+0x0): multiple definition of `AccelStepper::targetPosition()’
(.text+0x0): multiple definition of `AccelStepper::currentPosition()’
(.text+0x0): multiple definition of `AccelStepper::setCurrentPosition(long)’
(.text+0x0): multiple definition of `AccelStepper::computeNewSpeed()’
(.text+0x0): multiple definition of `AccelStepper::moveTo(long)’
(.text+0x0): multiple definition of `AccelStepper::move(long)’
(.text+0x0): multiple definition of `AccelStepper::setMaxSpeed(float)’
(.text+0x0): multiple definition of `AccelStepper::setAcceleration(float)’
(.text+0x0): multiple definition of `AccelStepper::maxSpeed()’
(.text+0x0): multiple definition of `AccelStepper::AccelStepper(unsigned char, unsigned char, unsigned char, unsigned char, unsigned char, bool)’
(.text+0x0): multiple definition of `AccelStepper::AccelStepper(void ()(), void ()())’
(.text+0x0): multiple definition of `AccelStepper::speed()’
(.text+0x0): multiple definition of `AccelStepper::setMinPulseWidth(unsigned int)’
(.text+0x0): multiple definition of `AccelStepper::setPinsInverted(bool, bool, bool)’
(.text+0x0): multiple definition of `AccelStepper::setPinsInverted(bool, bool, bool, bool, bool)’
(.text+0x0): multiple definition of `AccelStepper::runToPosition()’
(.text+0x0): multiple definition of `AccelStepper::runSpeedToPosition()’
(.text+0x0): multiple definition of `AccelStepper::runToNewPosition(long)’
(.text+0x0): multiple definition of `AccelStepper::stop()’
libraries\AccelStepper\MultiStepper.cpp.o (symbol from plugin): In function `MultiStepper::MultiStepper()’:
(.text+0x0): multiple definition of `MultiStepper::MultiStepper()’
sketch\MultiStepper.cpp.o (symbol from plugin):(.text+0x0): first defined here
(.text+0x0): multiple definition of `MultiStepper::addStepper(AccelStepper&)’
(.text+0x0): multiple definition of `MultiStepper::moveTo(long*)’
(.text+0x0): multiple definition of `MultiStepper::run()’
(.text+0x0): multiple definition of `MultiStepper::runSpeedToPosition()’
libraries\Wire-master\Wire.cpp.o (symbol from plugin): In function `TwoWire::available()’:
(.text+0x0): multiple definition of `TwoWire::available()’
sketch\Wire.cpp.o (symbol from plugin):(.text+0x0): first defined here
(.text+0x0): multiple definition of `TwoWire::rxBufferLength’
(.text+0x0): multiple definition of `TwoWire::rxBufferIndex’
(.text+0x0): multiple definition of `TwoWire::read()’
(.text+0x0): multiple definition of `TwoWire::rxBuffer’
(.text+0x0): multiple definition of `TwoWire::peek()’
(.text+0x0): multiple definition of `TwoWire::flush()’
(.text+0x0): multiple definition of `TwoWire::onReceiveService(unsigned char*, int)’
(.text+0x0): multiple definition of `TwoWire::user_onReceive’
(.text+0x0): multiple definition of `TwoWire::onRequestService()’
(.text+0x0): multiple definition of `TwoWire::user_onRequest’
(.text+0x0): multiple definition of `TwoWire::txBufferIndex’
(.text+0x0): multiple definition of `TwoWire::txBufferLength’
(.text+0x0): multiple definition of `TwoWire::write(unsigned char const*, unsigned int)’
(.text+0x0): multiple definition of `TwoWire::transmitting’
(.text+0x0): multiple definition of `TwoWire::write(unsigned char)’
(.text+0x0): multiple definition of `TwoWire::txBuffer’
(.text+0x0): multiple definition of `TwoWire::TwoWire()’
(.text+0x0): multiple definition of `Wire’
(.text+0x0): multiple definition of `TwoWire::begin()’
(.text+0x0): multiple definition of `TwoWire::begin(unsigned char)’
(.text+0x0): multiple definition of `TwoWire::begin(int)’
(.text+0x0): multiple definition of `TwoWire::end()’
(.text+0x0): multiple definition of `TwoWire::setClock(unsigned long)’
(.text+0x0): multiple definition of `TwoWire::setSDA(unsigned char)’
(.text+0x0): multiple definition of `TwoWire::setSCL(unsigned char)’
(.text+0x0): multiple definition of `TwoWire::requestFrom(unsigned char, unsigned char, unsigned char)’
(.text+0x0): multiple definition of `TwoWire::requestFrom(unsigned char, unsigned char)’
(.text+0x0): multiple definition of `TwoWire::requestFrom(int, int)’
(.text+0x0): multiple definition of `TwoWire::requestFrom(int, int, int)’
(.text+0x0): multiple definition of `TwoWire::beginTransmission(unsigned char)’
(.text+0x0): multiple definition of `TwoWire::txAddress’
(.text+0x0): multiple definition of `TwoWire::beginTransmission(int)’
(.text+0x0): multiple definition of `TwoWire::endTransmission(unsigned char)’
(.text+0x0): multiple definition of `TwoWire::endTransmission()’
(.text+0x0): multiple definition of `TwoWire::onReceive(void (*)(int))’
(.text+0x0): multiple definition of `TwoWire::onRequest(void (*)())’
libraries\Arduino-PID-Library-master\PID_v1.cpp.o (symbol from plugin): In function `PID::Compute()’:
(.text+0x0): multiple definition of `PID::Compute()’
sketch\PID_v1.cpp.o (symbol from plugin):(.text+0x0): first defined here
(.text+0x0): multiple definition of `PID::SetTunings(double, double, double, int)’
(.text+0x0): multiple definition of `PID::SetOutputLimits(double, double)’
(.text+0x0): multiple definition of `PID::SetTunings(double, double, double)’
(.text+0x0): multiple definition of `PID::SetSampleTime(int)’
(.text+0x0): multiple definition of `PID::Initialize()’
(.text+0x0): multiple definition of `PID::SetMode(int)’
(.text+0x0): multiple definition of `PID::SetControllerDirection(int)’
(.text+0x0): multiple definition of `PID::PID(double*, double*, double*, double, double, double, int, int)’
(.text+0x0): multiple definition of `PID::PID(double*, double*, double*, double, double, double, int)’
(.text+0x0): multiple definition of `PID::GetKp()’
(.text+0x0): multiple definition of `PID::GetKi()’
(.text+0x0): multiple definition of `PID::GetKd()’
(.text+0x0): multiple definition of `PID::GetMode()’
(.text+0x0): multiple definition of `PID::GetDirection()’
collect2.exe: error: ld returned 1 exit status
exit status 1
Error compiling for board Arduino Pro or Pro Mini.
