Satnogs v0.2.5 released
Hi all,
In the past couple of weeks we have cut a small but new release of the SatNOGS client: v0.2.5
The changes are listed below. In the weeks to come we will be focusing on a web based interface for the client itself which will help to make configuration and status determination a lot easier.
  • Support for hardware radios
  • SATNOGS_HARDWARE_RADIO including arguments for arecord and support for SATNOGS_ARECORD_DEVICE
  • pyephem dependency update
  • Support for fixed-antenna stations through the SATNOGS_USE_ROTATOR option
If you install from pip you should be able to do a pip upgrade satnogsclient otherwise look for the v0.2.5 tag in github.
