I used and was very happy with the SatNOGS station monitor that Wose put together a few years back. I’m refurbishing my ground stations and am wondering if anyone is still using this tool. If so:
Does it run with the current Satnogs software?
Is there any documentation for installation/configuration?
Yes, it still works. I had some issue building it but had some trial and error done.
My method is in the docker addons I use and useage roughly documented here
I was not able to make it build reliably with debian packages for rust, it is probably possible but I am not that good with rust.
