One of my satnogs stations is running on a Intel Centrino Duo | Debian Buster (i386).
When I run satnogs-setup and execute an update it will remove the ansible version that is installed via the debian buster packages and replaces it with the package that is made available via deb http://ppa.launchpad.net/ansible/ansible/ubuntu trusty main.
After that the satnogs setup isn’t working anymore because it can’t find the python anisble module.
After some debugging I found out that the satnogs-setup replaces the ansible with a python2 version.
So every time after an update I need to remove and replace the ansible version with the buster package release.
I guess something is wrong with the i386 playbook.
Can this be fixed?
Thanks in advance.
