Hello everyone.
After having already produced 2 rotors, version 2, I am starting the construction of the Satnogs V.3 rotor with aluminum profiles and a 40 mm boom. to be able to attack a 1.7 Ghz antenna grid (LTE version) that combined with the SAWFILTER GOES Nooelec for 1.7 Ghz I will be used to track the weather satellites in HRPT.
I would like to ask some questions about the construction, and I hope you can help me:
What is the GEAR RATIO of the new V.3 rotor with stepper motor of 1.59 Nm 2 A is 1:54 or 1:60?
I already have the PCB for both version 1.2 and version 2 I think (as pictured attached), I wanted to ask if the version 1.2 is compatible with the rotor Satnogs version 3 or needs by force of the latest version of PCB (V. 2.2).
If it is necessary for version 2.2 my 2 version is that good in the picture?
I thank you in advance for the answer and I hope to be able to trace the weather satellites in HRPT with the new version 3 rotor of your legendary TEAM
Ciao
Massimiliano Caturegli - IZ5RZR
