Hello together!
I am trying to get our new S-Band ground station (FHWN S-Band) up in testing mode soon. For a frequency range of 2.4 - 2.45 GHz we are aiming on a rotator resolution of 0.2°.
Unfortunately, the SatNOGS Client only supports integer numbers for the rotator threshold (SATNOGS_ROT_THRESHOLD) within the rotator settings. This was sufficient, for our UHF ground station, but not for S-Band communication.
Exists there a solution to use the SatNOGS Client for antenna tracking with a rotator threshold <1° (float numbers)?
Some information about our RX S-Band setup:
- 4.5m parabolic dish with LHCP helix dish feed (2.4 - 2.45 GHz)
- SPIG BIG RAS/HR rotator with 0.1° resolution, controlled with a SPID MD-01 controller (Rot2Prog)
- SatNOGS Client running on a RaspberryPi 4
- SDR: ADALM PlutoSDR
Many thanks!
Cheers,
Alex, oe3ala
