Satnogs Raspi remote login
Hi All
I am wondering how you users remotely login to your Satnogs Raspberry Pi,
For example on my other RPi with a “Desktop” I can enable VNC or SSH and run headless,
but the Satnogs Pi is CLI only (no desktop) so is it possible to install something like VNC or SSH to enable remote login ?
Thanks for any help.
latest version of satnogs are running inside docker. so its not problem if you running it on a desktop version of raspberry pi, so you can remote your raspberry deskop with your favourite vnc.
to install satnogs and docker automatic , just run this command from your desktop terminal:
$ curl -sfL https://satno.gs/install | sh -s –
Excellent, and many thanks.
So you are saying I can have a desktop environment and have Satnogs on the same Raspi,
I was un aware this could be done,
Will give it a go later , Thanks again.
yes. right.
