Is it posible to install Satnogs Client on a Rpi 3 running spyserver?
Now, I have a rpi 3 running spyserver with an Airspy HF+ and a web server based on Flask for relay switching…
I don’t want to have 2 rpi if it’s possible to have everything on 1
Thanks, 73’s
EA5WA Juan Carlos
You can install the satnogs client on anything, but I’m not sure it will work well on the RPI. Aside from potential CPU load issues, you will likely encounter problems with too much traffic through a single USB interface.
Ok. Thanks for your help…
I’ll continue with a separate Rpi…
