SatNOGS Network Release: 1.116
We have a new release for SatNOGS Network, which will be deployed in the next minutes. It comes with some changes that will limit the performance issues of the last days by caching SQL queries and specific requests on the station API.
If you notice anything unexpected, let us know either by posting here or opening a new issue in Issues · librespacefoundation / SatNOGS / satnogs-network · GitLab
More details can be found in:
I lost the observations page for some time, and have not been able to log in since, even though I have not recently changed my password.
I’ll send you a pm to find out what’s going wrong.
As @K2PI noted there is an issue with the login process, due to unknown reason it shows to take forever.
Actually it can take up to 5min to log you in but eventually it will. I’m trying to find out the reason and fix it, until then please be patient when you login.
Just a small inconvenience, the latest update is no longer sorting on ID
If possible, can this be changed back?
Sure, I’ll open tomorrow an issue about it to track it and change it.
The problem with the delay in SatNOGS Network login is now solved, the problem was a IPv6 networking issue between the servers. Thank you for your patience!
