if you have problems with the font rendering in putty (wrong colors, missing characters) check that you have the latest putty version and a font with all glyphs. See SatNOGS station monitor v0.3.x
Check your data_path configuration:
- there is an underscore between
dataandpathnot a space - the default data path on the SatNOGS RPi image is `/tmp/.satnogs/data
