SATNOGS in isolated area
Anybody thought of adding solar for power and iridium modem for satnogs station in an isolated area?
That should be really straighforward.
For that although it might be easy to setup, the cost of running it would be really high.
Do you have something specific in mind?
Hi Pierros,
I was just thinking outside the box :wink: to get coverage where we dont have coverage yet.
Maybe need to look at how we can get bandwidth lower or look at more distributed system so data is stored at the system till you have access. Maybe eshailsat can also be used?
Just and idea to get people thinking, the clever or more practical people might have some solutions?
At the AMSAT Symposium a few weeks back, W2BFJ (/stations/12) gave a presentation on deploying foxtelem kits and getting global coverage… Obviously, Antarctica was brought up as a ā€œwould love to have this!ā€.
Got me thinking a lot about what we would do if we were given a chance at a ground station in Antarctica. Bandwidth (iridium) is at a premium there. Would we disable the uploading of the .ogg files and stick with waterfall and decoded data? I think there would be a strong argument for that. We’re decoding enough satellites now where that would be very beneficial.
Is anyone working to get satnogs nodes into Africa? I’d be up for helping if anyone is…
There isn’t anything active currently. It would be nice to try if there are any contacts with universities or radio amateur clubs or individuals.
Perhaps you can use the Starlink network for this when it becomes fully operational. Or depending how remote, you could use a cellular modem.
Hey,
I live at 78 degrees N, Svalbard. We have the largest civilian satellite groundstation here in town.
I have been playing with the thought of building a ground station for a long time but I am a novice in almost all the fields of this build. I would like to build a directional antenna and just wanted to hear if there are people that would like to give me some extra help or help out with the equipment for a station in this remote place.
I have access to a 3D printer, I know soldering and have some arduino unos and 2 currently unused raspberry pi 3 model B v1.2 laying around.
Regards
Ti-Time
Hey @ti-time, welcome to our community! I’ve sent you a message to see how we can help :slight_smile:
Hi @ti-time,
IMO, considering the climatic conditions there, I believe that a patch antenna system could be a good solution for both the VHF and UHF bands.
Take a look at this paper [https://orbanmicrowave.com/the-basics-of-patch-antennas/] , that is a good starting point.
Also this [https://vk6ysf.com/patch_Antenna_435MHz.htm] it’s really interesting, maybe making a single antenna; scaling to other ferquency it’s simple.
I’m looking to do some test in this field, but no much time at present…
de I3VFJ, Vittorio
For Africa we could imaging using Es’Hail2 in some way for the communication. Es’Hail2 communication would of course only occure between observations. The issues would be
  • A specific protocol would be needed instead of a plain internet connection
  • There might be a legal issue or special authorization needed to operate an ā€˜automatic station’
As for Antarctica, DP0GVN (German Antarctic station Neumayer III) have a WSPR project there and very active online. So, you can contact them and ask, if is it possible to set up SATNOGS station as well.
Paging our German friends here: @kerel @DL4PD . Can you reach out please?
I know from Peter, @db2os, that they have a FunCube station already setup there - maybe Peter can give us an idea on how realistic this could be.
Yes, I’m here… :wink:
I will try to give some insights regarding Antarctica later…
Peter
Unfortunately I had to disable both of our AMSAT-DL SatNOGS Stations at DP0GVN Neumayer III in Antarctica. UHF seems to have lost its connection to the antenna, while extreme RFI on VHF makes it practically unusable. A maintenance team and a new crew will arrive by the end of this year with several radio amateurs and hopefully they can fix before the Antarctic summer ends.
73 de Peter DB2OS
BTW: You would probably assume Antarctica is a very ā€œquietā€ place, but the Station is full of experiments, various kind of atmospheric radars, communications equipment etc.. it’s a very noisy environment!
wow thank you for the report. so you stay there ?
at least i had make some observations there.. lol. thank you!
