Alguna manera de instalar satnogs_gr-satélites en windows 10, o de agregarlo en gnu radio (con gr-satellites) instalado con radioconda. gracias
Ik heb geen idee wat je vraagt, misschien dat je de moeite kunt nemen om je vraag te vertalen zodat we hem eventueel kunnen beantwoorden.
(post deleted by author)
… Any way to install satnogs_gr-satellites on windows 10, or add it to gnu radio (with gr-satellites) installed with radioconda. Thank you.
Hello , help plis
Based on this link Installation — gr-satellites 5.1.0-git documentation it should be possible, but I have no experience with GNUradio on Windows.
if possible. There are packages that install the full version, but in the case of gr_satnogs I haven’t found a way, since some satnogs libraries are necessary.
For installing gr_satellites you do not need gr_satnogs!
