HI.
I like to see the beacons of NOAA 15-19. But: If I want to add a new transponder with 137.770 MHz for NOAA 19 for e. g. DB says it is only possible between 137 and 138. Howto?
HI.
The suggestions on DB are expressed in Hz, not in MHz. So if you use 137770000 it should be ok
LOL. Ok. Will give it a try :).
