Hello from Cyprus, as part of our project we are planning to make our first Satnogs Linux tutorial video for dummies. This will enable non technical or expert people and students to basically understand the whole process of the installation. And it would eliminate the scare factor of actually trying to work with the Linux.
Do you know of any tutorial videos also do you have any links that you can share .
https://wiki.satnogs.org/SatNOGS_Client_Ansible
Also i think a good idea is if someone has 40 minutes for a teamviewer session where we can actually get to ask you a lot of silly questions while trying to install satnogs client, we will then record the video, edit it and then produce a very easy non technical installation tutorial.
Do you think this is a good idea? Do you have any recommendations?
