The SATNOGS_PPM_ERROR option have no effect on the latest version of the SatNOGS client system. Previously had the opportunity to pass parameters for librtlsdr using the --dev-args ( SATNOGS_DEV_ARGS ).
Below is a screenshot for setting the Soapy Source radio parameters in Gnuradio flowgraph.
As you see, Soapy Source block have special setting 'Freq Correction" ( it works! ). The following code corresponds to it:
self.soapy_source_0 = \ soapy.source(1, 'rtlsdr', '', samp_rate*40, "fc32") self.soapy_source_0.set_frequency(0, 436.9e6) self.soapy_source_0.set_gain_mode(0, False) self.soapy_source_0.set_antenna(0, 'RX') self.soapy_source_0.set_dc_offset_mode(0, True) self.soapy_source_0.set_frequency_correction(0, 39)
SoapySDRUtil application allow to print information about the RTL-SDR.
You can see parameter:
Freq Correction [corr]: Default 0 (parts per million)
Unfortunatelly, parameter corr in SATNOGS_DEV_ARGS have no effect also (see dev_args: âcorr=37â in Metadata>radio ).
Here information for my RTLSDR:
Soapy SDR â the SDR abstraction library
Probe device driver=rtlsdr
â Device identification
driver=RTLSDR
hardware=UNKNOWN
index=0
origin=GitHub - pothosware/SoapyRTLSDR: SoapySDR RTL-SDR Support Module
â Peripheral summary
Channels: 1 Rx, 0 Tx
Timestamps: YES
Time sources: sw_ticks
Other Settings:
â RX Channel 0
Full-duplex: NO
Supports AGC: YES
Stream args:
Antennas: RX
Full gain range: [0, 0] dB
TUNER gain range: [0, 0] dB
RF freq range: [24, 1764] MHz
Perhaps SATNOGS_PPM_ERROR is still required?
