I’m trying to install satnogs-client on my ubuntu 16. I followed the instruction in the satnogs Documentation, but i had a problem with setting up mkvirtualenv
1- git clone https://gitlab.com/liberspacefoundation/satnogs/satnogs-client.git
2- mkvirtualenv satnogs-client -a
(when i excute the above command i get an error “Cannot associate project with , it is not a directory”
help ?
n5fxh
March 31, 2018, 12:02pm
#4
this phase worked with me. Precisely, I think it was:
cd satnogs-client
mkvirtualenv satnogs-client -a .
with a point at the end (probably the above mentioned missing directory)
m0glu
March 6, 2022, 6:48pm
#5
I have a problem during installation.
I followed this instruction: SatNOGS Client Ansible - SatNOGS Wiki
When I ran this ansible-playbook -i production/inventory/hosts -K site.yml
I got this error:
BECOME password:
[WARNING]: Invalid characters were found in group names but not replaced, use -vvvv to see details
Executing playbook site.yml
satnogs-setups on hosts: satnogs-setups -
Gathering Facts…
Create needrestart directory for Raspbian…
Configure needrestart for Raspbian…
Install or remove satnogs-setup system dependencies…
Retrying… (1 of 4)
Retrying… (2 of 4)
Retrying… (3 of 4)
[WARNING]: Updating cache and auto-installing missing dependency: python-apt
satnogs failed | item: {‘name’: ‘python-apt’} | msg: E: Package ‘python-apt’ has no installation candidate | stdout: Reading package lists…
root@newsdrlinuxv11:/home/satnogs/satnogs-client-ansible# which python
/usr/bin/python
root@newsdrlinuxv11:/home/satnogs/satnogs-client-ansible# pip list
Package Version
python-apt 2.2.1
root@newsdrlinuxv11:/home/satnogs/satnogs-client-ansible# python -V
Python 2.7.18
Debian GNU/Linux 11.2.0 Bullseye
Thank you for your advice
73’ Tony
I have run into your same problem. I am on Debian11 run inside VMware (since I don’t have a raspberry pi)
PE0SAT
March 11, 2022, 5:25pm
#7
For now use Debian buster. (Debian old stable)
I have two systems running on that release and used the satnogs wiki for installation.
cat /etc/os-release
PRETTY_NAME="Debian GNU/Linux 10 (buster)"
NAME="Debian GNU/Linux"
VERSION_ID="10"
VERSION="10 (buster)"
VERSION_CODENAME=buster
ID=debian
HOME_URL="https://www.debian.org/"
SUPPORT_URL="https://www.debian.org/support"
BUG_REPORT_URL="https://bugs.debian.org/"
Gotcha, thanks for the prompt reply!
I managed to get it working installing everything manually in the end even though, although it was a bit painful. I’ll try buster if anything goes wrong
PE0SAT
March 11, 2022, 5:35pm
#9
I know it is possible, but you need to have some Linux experience, have a look at this install log that I created when installing and configuring a SatNOGS client running on Ubuntu server.
Ubuntu install log
This manual install can also be used on other Linux apt
distribution.
i installed satnogsclient on debain 11
how satnogs client run
how it run
please help me
jebba
April 8, 2022, 4:49pm
#11
@shamika_sat Perhaps this will help:
PE0SAT
April 9, 2022, 8:26am
#12
I also replied via matrix, use Debian 10 / Buster and the SatNOGS Anisble Wiki to install.
PE0SAT
April 9, 2022, 5:30pm
#13
I did a new Debian installation and shared the information on the following page:
https://www.pe0sat.vgnet.nl/satellite/satnogs/debian/
This should help you in getting an up and running SatNOGS client on Debian.
