After having updated my client to version 1.7 on a Rapsberry Pi 3 I tried the first and best pass which turned out to be a XW-2E pass in CW mode. The client tried to start tracking OK but gave up immediately with the message:
satnogs_cw_decoder.py: error: unrecognized arguments: --udp-dump-port=57356
Believing I hadn’t done a complete update I rerun satnogs-upgrade but I didn’t have much luck here either:
Calculating upgrade... Done
The following packages will be upgraded:
libuhd3.15.0 soapysdr0.7-module-airspy soapysdr0.7-module-audio soapysdr0.7-module-bladerf
soapysdr0.7-module-hackrf soapysdr0.7-module-lms7 soapysdr0.7-module-osmosdr uhd-host
8 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 9,041 kB/11.6 MB of archives.
After this operation, 3,072 B of additional disk space will be used.
Do you want to continue? [Y/n]
Get:1 http://download.opensuse.org/repositories/home:/librespace:/satnogs/Raspbian_10 ./ uhd-host 3.15.0.0-4satnogs1 [9,041 kB]
Err:1 http://download.opensuse.org/repositories/home:/librespace:/satnogs/Raspbian_10 ./ uhd-host 3.15.0.0-4satnogs1
File has unexpected size (9040820 != 9040824). Mirror sync in progress? [IP: 2001:6b0:17:f0a0::fd 80]
Hashes of expected file:
- SHA256:495aa8dea780e9473e4a7123df66709aa6680bcc16cfe201718061083a0291cf
- SHA1:2d4bcc7f6ede1c5d8baccc42ca7c65ab5ca16ee5 [weak]
- MD5Sum:9c9060affc1ff4ea5aadb160a8d325c0 [weak]
- Filesize:9040824 [weak]
E: Failed to fetch http://ftp.lysator.liu.se/pub/opensuse/repositories/home:/librespace:/satnogs/Raspbian_10/armhf/uhd-host_3.15.0.0-4satnogs1_armhf.deb File has unexpected size (9040820 != 9040824). Mirror sync in progress? [IP: 2001:6b0:17:f0a0::fd 80]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
root@bastro:~#
I have tried both options mentioned above, but the doesn’t change anything.
So how do I best proceed from here? Is there another repository for satnogs than OpenSUSE?
PS Does this edotor have a ‘preview’ function? I’m writing this more or less in the dark.
