After a standard installation of satnogs with an Ansible I decided to test satnogs-client build from source in virtualenv environment. I followed this guide from docs.
I got stuck at this error that I can’t get through. I thought that maybe satnogs_cw_decoder.py is misconfigured so I compiled all satnogs-flowgraphs and replaced files.
File "/usr/bin/satnogs_cw_decoder.py", line 459, in <module>
main()
File "/usr/bin/satnogs_cw_decoder.py", line 444, in main
tb = top_block_cls(antenna=options.antenna, bb_freq=options.bb_freq, bfo_freq=options.bfo_freq, bw=options.bw, dc_removal=options.dc_removal, decoded_data_file_path=options.decoded_data_file_path, dev_args=options.dev_args, doppler_correction_per_sec=options.doppler_correction_per_sec, enable_iq_dump=options.enable_iq_dump, file_path=options.file_path, gain=options.gain, gain_mode=options.gain_mode, iq_file_path=options.iq_file_path, lo_offset=options.lo_offset, other_settings=options.other_settings, ppm=options.ppm, rigctl_port=options.rigctl_port, rx_freq=options.rx_freq, samp_rate_rx=options.samp_rate_rx, soapy_rx_device=options.soapy_rx_device, stream_args=options.stream_args, tune_args=options.tune_args, udp_IP=options.udp_IP, udp_port=options.udp_port, waterfall_file_path=options.waterfall_file_path, wpm=options.wpm)
File "/usr/bin/satnogs_cw_decoder.py", line 121, in __init__
self.satnogs_waterfall_sink_0 = satnogs.waterfall_sink(audio_samp_rate, rx_freq, 10, 1024, waterfall_file_path, 1)
File "/usr/lib/python3/dist-packages/satnogs/satnogs_swig0.py", line 5179, in make
return _satnogs_swig0.waterfall_sink_make(samp_rate, center_freq, rps, fft_size, filename, mode)
RuntimeError: Could not create file for writing
satnogsclient.observer.observer - INFO - Tracking stopped.
satnogsclient.observer.worker - INFO - Tracking stopped.
satnogsclient.scheduler.tasks - INFO - Trying to GET observation jobs from the network
satnogsclient.observer.observer - INFO - Observation Finished
satnogsclient.observer.observer - INFO - Executing post-observation script.
satnogsclient.observer.observer - ERROR - Failed to rename encoded file
satnogsclient.observer.observer - ERROR - Failed to rename data file
satnogsclient.observer.observer - INFO - Creating waterfall plot.
satnogsclient.observer.waterfall - INFO - Read waterfall file
satnogsclient.observer.observer - ERROR - No waterfall data file found</msg>
I can post the whole log, but this part seems to be enough.
Has this error happened to anyone else? The individual tests of these modules were successful and created an .ogg file.
