I have done this last weekend an install using Debian Buster and also gr-satnogs 2.0.1. I have to compile rtl_biast as explained in the wiki. After that, checked it works running the executable from the directory : $ /home/pi/rtl_biast/build/src/rtl_biast -b 1 Found 1 device(s): 0: Realtek, RTL2838UHIDIR, SN: 00000001 Using device 0: Generic RTL2832U OEM Found Rafael Micro R820T tuner
Then, check permissions, so that the satnogs user can launch the script from satnogs-client. Then, set the pre/post observation scripts in satnogs-setup.
By the way, I did have problems because misconfiguring a new parameter, SATNOGS_SOAPY_RX_DEVICE, which in my case, the correct value is driver=rtlsdr.
I must admit that I did not try to add the shortcut in my pre-observation script since I had the values in the SATNOS_DEV_ARGS. I will give it a try but last night it was faster to just solder a power supply to the LNA.
