Satellite suggestion: PARKINSONSAT PSAT NO-84 40654
This one is not in the db and is fairly easy to copy vhf 145.825 nfm afsk 1k2 packet
http://aprs.org/psat.html
altho it is not listed in many common sources like http://www.celestrak.com/NORAD/elements/amateur.txt
it is on http://www.amsat.org/amsat/ftp/keps/current/nasabare.txt :
NO-84
1 40654U 15025D 19065.24533510 .00012471 00000-0 17877-3 0 05530
2 40654 054.9868 288.5620 0146234 059.5152 302.0226 15.45180348096299
Packet Up/Downlink . . 145.825 1200 baud APRS (shared with ISS, PCSAT, UO11 and others!) Aliases are ARISS and APRSAT <<< verified downlink, 8 packets decoded this morning >>>
PSK31 Downlink . . . . . 435.350 MHz +/- 5 kHz FM (300 mw)
PSK31 Uplink . . . . . . . . 28.120 MHz +2 kHz PSK31 SSB (75 watts into omni vertical authorized)
It is in the DB with first SatNOGS observation dating back to 2017.
Ok - I had the wrong id, thanks!
