How should I add information in the description of a satellite, (DIY-1)?
Regards.
Regards.
Hi LW2DTZ,
a short guide on how to edit a satellite in satnogs-db:
Sign Up / Login to SatNOGS DB
Open DIY 1 satellite page, then press “Edit”:
Press “Edit DIY 1” in the drop-down menu:
Edit the entry in the popup modal:
Press “Update” at the bottom of the update modal. If there is the following dialog, confirm with “Leave page” (the information you entered will be saved anyway)
Done, congratulations!
Once your edit has been sent, it is stored as suggestion for review by a moderator. Once a moderator approved the suggestion the satellite entry will contain your changes.
Thank you for reaching out! Please let us know if everything worked or in case there are any other problems.
Sincerely,
kerel / Fabian Schmidt
Thanks for your help Fabian @kerel !
