Now I plan to use this setup for receiving an upcoming LEO Satellit around 2403Mhz.
Actually I don’t know a Satellit which is transmitting close to this frequency.
How to test the whole setup from the antenna to SATNOGS e.g. with SATNOGS-monitor?
I have running here a station which works actually in the 2m Band. I can test with different Satellites but only if they are “visible”.
Receiving a Sat which is not in space is not possible with SATNOGS-monitor.
I have here a local source for that band but how to bring SATNOGS-monitor to receive it?
Is there a way to put the monitor in a “transparent” mode?
Any other idea how I could test my setup?
(Static I can receive a source with the converter thats no problem)
73
Armin
HB9MFL
Apart from challenges in the S-band and 13cm I guess currently the biggest is being able to configure the right RX freq when using a down converter like in your setup.
I need to have a look in the SatNOGS client documentation to see if there is an offset mode option.
In the meantime if you want to have an idea on satellites received in S-band and 13cm, have a look at the transmitters selection visiting the SatNOGS db
frequency offset not supportet yet, as far as I know. it can be done, hardcoded in the flowgraphs or properly implemented but it is some work to be done in at least a few repos.
WIP: flowgraphs and client, feel free to try it out. I will probably include these after some testing, in my sa2kng branches that goes into the corresponding docker images.
As you can see now an OFFSET of 2256.000000MHz is set.
Set in ADVANCED menu under RADIO is the the argument SATNOGS_TUNE_ARGS and here I set OFFSET=2256000000 (offset frequency in Hz).
See the observation https://network.satnogs.org/observations/8869684/
Just at rise may be a short signal from satellite. Announced TX is for July 24 on this frequency, The signal midpass is from my generator coupled over the air on 2402.400 as testsignal. Dopplercorrection >> OK and RX frequnency >> OK. Does somebody has a list of the parameters that could be set under SATNOGS_TUNE_ARGS??
