S-Band Ground Station
Hey! LSF is building a S-Band GS in Kalamata - Greece.
For these purpose a BOM is developed:
  • Rotator:
  1. SPID, type RAS/HR Azimuth & Elevation Rotor
  2. Antenna mounting bracket, SPID BR-02
  3. MD-02 Rotator Controller
  4. Power Supply Module: PS-02
  5. Additional parts like cables for motors and position sensors and connectors
Note: The rotator controller communicates with single board computer via hamlib. An issue of controller is after a few slews we are getting “PULS TIMEOUT MOTOR 2”, any thoughts?
  • RF - RX Chain
  1. LHCP/RHCP Helix dish feed, 2.1 - 2.6 GHz (100 MHz Bandwidth)
  2. Feeder Box:
    The feeder box will be placed near to the antenna feeder.
    Measurements of feeder box:
Gain: 7.85dB @ 2.2GHz, measured at the SDR port without using cable ecoflex-10 but a RF cable mini-circuits 141-10NM+. Because the gain of feeder box is low, we measure the gain of LNA only.
The Gain: 11.58dB @ 2.2GHz, which is near to the datasheet value, 12.4dB @ 2.0GHz. So the total losses of the feeder box are: 3.73dB (while the losses which are calculated from diagrams are ~1.3dΒ). Any thought?
Notes:
  1. SDR side
    The SDR are placed inside to the client box.
Congrats to @pierros and @BOCTOK-1 !!!
According to the block diagram of the station, the bandpass filter is placed before the low-noise amplifier. Why is that? The BPF has a significant insertion loss of 1.6 dB (minimum; at f_center), as confirmed by the datasheet:
Unless the out-of-band RFI is incredibly significant (unlikely), and the gain of the LNA is very high (~30 dB), which is not, then the LNA should be placed before the BPF and not vice versa.
Hi azisi,
Nice RF-designs and documentation.
Not sure where I should inform people about this but the MD-02 rotator controller has a design flaw that everyone should consider if using it actively. The controller applies 24V to motor wires/coils when the controller is powered off or stand-by. The potential stays same on both wires so the motor won’t turn BUT because the motor’s copper coils are in higher potential than the grounded body of the motor, a thin film of water on the inner surfaces of the motor coil will make the current run. This causes the copper to corrode away from the motor until no copper is left and the motor’s body is full of black copper oxide. Powered motor cables can also cause unwanted dish rotation when one of the cables gets accidentally shorted to ground! Moisture can get in to the motor from a hole in the bottom of motor. The hole is there to let condensation water out so it shouldn’t be plugged but this hole also let’s the moisture in…
I’m not sure what is the best way to solve the issue but we decided to implement our own controller with STM32 and stock PWM motor drivers.
Hey! According to datasheets,
The noise factor, F = F1 + (F2-1)/G1 and Noise Figure, NF(dB)=10*log(F) is:
  • BPF+LNA: 2.1dB
  • LNA+BPF: 0.58dB
So, you are right. But the position of BPF it depends on the noise of the environment where the ground station is placed. For example in Athens, a noisy environment, the BPF before the LNA is necessary to reduce the noise in input of LNA (due to inter-modulation in output). This S-band ground station is placed in Kalamata, so we must change the position of LNA and BPF (LNA+BPF). Thanks for your feedback!!
:beers:
Thanks for the feedback!
Do you have the source files (schematic and PCB) of the controller available?
Cheers! Happy to help.
Station is up now and running! Congrats to @azisi and @BOCTOK-1 for all the work around it.
