New install within Debian 10 virtual machine using RSP1A. No waterfall and RuntimeError shown below. RSP1A runs fine in CubicSDR. I’ve tried both the v2 and v3 of the SDRPlay API, searchd through troubleshooting and referenced other’s RSP1A settings. I need help understanding possible causes. Many thanks!
Mar 16 23:01:28 debian satnogs-client[32744]: satnogsclient.observer.worker - DEBUG - Initial frequency: 437426923
Mar 16 23:01:28 debian satnogs-client[32744]: satnogsclient.observer.worker - DEBUG - Rigctld msg: 437436453
Mar 16 23:01:28 debian satnogs-client[32744]: satnogsclient.observer.orbital - DEBUG - Observer data: {‘lon’: -86.75529, ‘lat’: 34.71426, ‘elev’: 200}
Mar 16 23:01:28 debian satnogs-client[32744]: satnogsclient.observer.orbital - DEBUG - Satellite data: {‘tle0’: ‘0 AAUSAT CUBESAT 2’, ‘tle1’: ‘1 32788U 08021F 21075.48716827 .00000942 00000-0 90098-4 0 9992’, ‘tle2’: ‘2 32788 97.5028 74.0660 0010537 215.6845 144.3673 14.95442730699967’}
Mar 16 23:01:28 debian satnogs-client[32744]: satnogsclient.observer.orbital - DEBUG - Calculated data: {‘alt’: 0.21489737927913666, ‘az’: 3.250701665878296, ‘rng’: 1762103.75, ‘rng_vlct’: -6531.2763671875, ‘ok’: True}
Mar 16 23:01:28 debian satnogs-client[32744]: satnogsclient.observer.worker - DEBUG - Rigctld msg: 437436452
Mar 16 23:01:29 debian satnogs-client[32744]: Traceback (most recent call last):
Mar 16 23:01:29 debian satnogs-client[32744]: File “/usr/bin/satnogs_fsk.py”, line 522, in
Mar 16 23:01:29 debian satnogs-client[32744]: main()
Mar 16 23:01:29 debian satnogs-client[32744]: File “/usr/bin/satnogs_fsk.py”, line 505, in main
Mar 16 23:01:29 debian satnogs-client[32744]: tb = top_block_cls(antenna=options.antenna, baudrate=options.baudrate, bb_freq=options.bb_freq, bw=options.bw, dc_removal=options.dc_removal, decoded_data_file_path=options.decoded_data_file_path, dev_args=options.dev_args, doppler_correction_per_sec=options.doppler_correction_per_sec, enable_iq_dump=options.enable_iq_dump, file_path=options.file_path, framing=options.framing, gain=options.gain, gain_mode=options.gain_mode, iq_file_path=options.iq_file_path, lo_offset=options.lo_offset, other_settings=options.other_settings, ppm=options.ppm, rigctl_port=options.rigctl_port, rx_freq=options.rx_freq, samp_rate_rx=options.samp_rate_rx, soapy_rx_device=options.soapy_rx_device, stream_args=options.stream_args, tune_args=options.tune_args, udp_IP=options.udp_IP, udp_port=options.udp_port, waterfall_file_path=options.waterfall_file_path)
Mar 16 23:01:29 debian satnogs-client[32744]: File “/usr/bin/satnogs_fsk.py”, line 96, in init
Mar 16 23:01:29 debian satnogs-client[32744]: tune_args, settings, samp_rate_rx, “fc32”)
Mar 16 23:01:29 debian satnogs-client[32744]: File “/usr/lib/python3/dist-packages/soapy/soapy_swig.py”, line 166, in make
Mar 16 23:01:29 debian satnogs-client[32744]: return _soapy_swig.source_make(nchan, device, dev_args, stream_args, tune_args, other_settings, sampling_rate, type)
Mar 16 23:01:29 debian satnogs-client[32744]: RuntimeError: soapy::source: Unsupported sample rate (2000000.000000). Rate must be in the range [8000.000000, 8000.000000] [16000.000000, 16000.000000] [22050.000000, 22050.000000] [32000.000000, 32000.000000] [44100.000000, 44100.000000] [48000.000000, 48000.000000] [96000.000000, 96000.000000]
Mar 16 23:01:30 debian satnogs-client[32744]: satnogsclient.observer.observer - INFO - Tracking stopped.
Mar 16 23:01:30 debian satnogs-client[32744]: satnogsclient.observer.worker - INFO - Tracking stopped.
Mar 16 23:01:32 debian satnogs-client[32744]: satnogsclient.observer.worker - INFO - Tracking stopped.
Mar 16 23:01:32 debian satnogs-client[32744]: satnogsclient.observer.observer - INFO - Observation Finished
Mar 16 23:01:32 debian satnogs-client[32744]: satnogsclient.observer.observer - INFO - Executing post-observation script.
Mar 16 23:01:32 debian satnogs-client[32744]: satnogsclient.observer.observer - INFO - Creating waterfall plot.
Mar 16 23:01:32 debian satnogs-client[32744]: satnogsclient.waterfall - INFO - Reading waterfall file
Mar 16 23:01:32 debian satnogs-client[32744]: satnogsclient.observer.observer - ERROR - No waterfall data file found
Probe device
[INFO] devIdx: 0
[INFO] hwVer: 255
– Device identification
driver=SDRplay
hardware=1803038B94
sdrplay_api_api_version=3.070000
sdrplay_api_hw_version=255
– Peripheral summary
Channels: 1 Rx, 0 Tx
Timestamps: NO
Other Settings:
* RF Gain Select - RF Gain Select
[key=rfgain_sel, default=4, type=string, options=(0, 1, 2, 3, 4, 5, 6, 7, 8, 9)]
* IQ Correction - IQ Correction Control
[key=iqcorr_ctrl, default=true, type=bool]
* AGC Setpoint - AGC Setpoint (dBfs)
[key=agc_setpoint, default=-30, type=int, range=[-60, 0]]
* BiasT Enable - BiasT Control
[key=biasT_ctrl, default=true, type=bool]
* RfNotch Enable - RF Notch Filter Control
[key=rfnotch_ctrl, default=true, type=bool]
* DabNotch Enable - DAB Notch Filter Control
[key=dabnotch_ctrl, default=true, type=bool]
– RX Channel 0
Full-duplex: NO
Supports AGC: YES
Stream formats: CS16, CF32
Native format: CS16 [full-scale=32767]
Antennas: RX
Corrections: DC removal
Full gain range: [0, 48] dB
IFGR gain range: [20, 59] dB
RFGR gain range: [0, 9] dB
Full freq range: [0.001, 2000] MHz
RF freq range: [0.001, 2000] MHz
CORR freq range: MHz
Sample rates: 0.0625, 0.096, 0.125, 0.192, 0.25, …, 6, 7, 8, 9, 10 MSps
Filter bandwidths: 0.2, 0.3, 0.6, 1.536, 5, 6, 7, 8 MHz
"versions": {
"satnogs-client": "1.4",
"satnogs-client-ansible": "202012231828",
"satnogs-flowgraphs": "1.3-1",
"gr-satnogs": "2.2.0.0-1",
"gr-soapy": "2.1.3.1-1",
"gnuradio": "3.8.2.0-14satnogs2",
"satnogs-config": "0.11"
"state": {
"is-applied": true,
"pending-tags": null
"system": {
"date": "2021-03-16T23:20:02.909178+00:00",
"distribution": {
"DESCRIPTION": "Debian GNU/Linux 10 (buster)",
"RELEASE": "10",
"CODENAME": "buster",
"ID": "Debian"
"pending-updates": false,
"platform": {
"system": "Linux",
"node": "debian",
"release": "4.19.0-14-amd64",
"version": "#1 SMP Debian 4.19.171-2 (2021-01-30)",
"machine": "x86_64",
"processor": ""
"memory": {
"total": 2066632704,
"available": 351350784,
"percent": 83.0,
"used": 1427353600,
"free": 214835200,
"active": 874344448,
"inactive": 559099904,
"buffers": 19439616,
"cached": 405004288,
"shared": 131878912,
"slab": 113233920
"disk": {
"total": 19994066944,
"used": 7521574912,
"free": 11433250816,
"percent": 39.7
"configuration": {
"satnogs_antenna": "RX",
"satnogs_log_level": "DEBUG",
"satnogs_rf_gain": "40",
"satnogs_rx_bandwidth": "600e3",
"satnogs_rx_samp_rate": "2e6",
"satnogs_soapy_rx_device": "device=sdrplay",
"satnogs_station_elev": "200",
"satnogs_station_id": "2097",
"satnogs_station_lat": "34.71426",
"satnogs_station_lon": "-86.75529"
