RSP1A no warterfall but data decoded
https://network.satnogs.org/observations/6998012/
trying new RPi4 installation with RSP1A SDR.
  • Blank waterfall
  • 12 Data decoded…
(refer to Adding SDRPlay RSPdx Support to SatNOGS · GitHub)
What did I do wrong?
VE2DSK
"versions": {
    "satnogs-client": "1.8.1",
    "satnogs-client-ansible": "202209101521",
    "gr-satnogs": "2.3.1.1-1",
    "gr-soapy": "2.1.3.1-1",
    "gnuradio": "3.8.2.0-14",
    "satnogs-config": "0.13.2"
"state": {
    "is-applied": true,
    "pending-tags": null
"system": {
    "date": "2023-01-07T21:01:12.326253+00:00",
    "distribution": {
        "DESCRIPTION": "Raspbian GNU/Linux 11 (bullseye)",
        "RELEASE": "11",
        "CODENAME": "bullseye",
        "ID": "Raspbian"
    "pending-updates": true,
    "platform": {
        "system": "Linux",
        "node": "raspberrypi",
        "release": "5.15.61-v7l+",
        "version": "#1579 SMP Fri Aug 26 11:13:03 BST 2022",
        "machine": "armv7l"
    "memory": {
        "total": 1963311104,
        "available": 1713364992,
        "percent": 12.7,
        "used": 164188160,
        "free": 1354932224,
        "active": 159539200,
        "inactive": 370528256,
        "buffers": 24494080,
        "cached": 419696640,
        "shared": 884736,
        "slab": 37863424
    "disk": {
        "total": 7478652928,
        "used": 4634525696,
        "free": 2485436416,
        "percent": 65.1
"configuration": {
    "hamlib_utils_rot_enabled": true,
    "hamlib_utils_rot_opts": "-m 601 -r /dev/ttyUSB0 -s 9600 -T 0.0.0.0",
    "satnogs_antenna": "RX",
    "satnogs_other_settings": "IFGR=30,RFGR=6",
    "satnogs_post_observation_script": "satnogs-post {{ID}} {{FREQ}} {{TLE}} {{TIMESTAMP}} {{BAUD}} {{SCRIPT_NAME}}",
    "satnogs_ppm_error": "0",
    "satnogs_pre_observation_script": "satnogs-pre {{ID}} {{FREQ}} {{TLE}} {{TIMESTAMP}} {{BAUD}} {{SCRIPT_NAME}}",
    "satnogs_rf_gain": "43.9",
    "satnogs_rot_baud": "9600",
    "satnogs_rot_model": "ROT_MODEL_GS232B",
    "satnogs_soapy_rx_device": "driver=sdrplay",
    "satnogs_station_elev": "50",
    "satnogs_station_id": "1461",
    "satnogs_station_lat": "45.651",
    "satnogs_station_lon": "-73.564",
    "satnogs_waterfall_autorange": false,
    "satnogs_waterfall_max_value": "-20",
    "satnogs_waterfall_min_value": "-75",
    "udp_dump_host": "127.0.0.1"
Maybe start with removing the following settings:
Many thanks Jan…
Sound good now…
VE2DSK
