RS5S 53310 Observation
While tracking RS5S for SSTV around 437.100 i hear a female voice saying RS4S and the SSTV signal is bouncing around from 437.113 down to 437.078 (Robot 36).
Is RS4S even a thing ? and if so i can’t seem to find any info on it.
Also is RS5S in the DB
Thanks
Karl.
https://db.satnogs.org/satellite/WJDU-4002-1128-3707-5455
You can search for satellites here, in top left corner:
Perfect Thanks.
Any idea why i can’t setup observations for it even though my station is set to 400-470mhz.
It only shows 10 available stations to gt observations from.
Thanks
Karl.
Maybe because it is listed as a frequency violator.
You should still be able to schedule it on your own ground station though, I think. It may be disabled though. Go to your ground station, hit Edit, then look for this line:
Scheduling of Frequency Violators by
and set it how you like (e.g. Everyone).
Worked like a charm thank you.
Karl.
437.093 at the end of the pass 7deg elev
RS4S Very loud on the 02:40z pass over Alberta.
