RS15S (ORBICRAFT-ZORKIY) Farwell Diploma
A small improvement:
Orbicraft-Zorkiy
1 47960U 21022AE  25102.15897904  .00000000  00000-0  14439-2 0    02
2 47960  97.4062  17.0921 0001223 229.4344 308.4688 16.36446926    06
One more fix with the observations over America:
Orbicraft-Zorkiy
1 47960U 21022AE  25102.15893227  .00000000  00000-0  13023-2 0    04
2 47960  97.4062  17.1056 0001223 229.4344 308.2000 16.36429756    04
A new TLE, it might not be as accurate as the previous ones, I’ll continue check it:
Orbicraft-Zorkiy
1 47960U 21022AE  25102.33632491  .00000000  00000-0  98023-3 0    02
2 47960  97.4062  17.3067 0001223 229.4344 273.8767 16.40989247    06
One more update, again I’m not 100% sure about its accuracy:
Orbicraft-Zorkiy
1 47960U 21022AE  25102.38189644  .00000000  00000-0  87341-3 0    05
2 47960  97.4062  17.3585 0001223 229.4344 183.3596 16.44433482    05
From observations over South Africa:
Orbicraft-Zorkiy
1 47960U 21022AE  25102.42938694  .00000000  00000-0  24646-3 0    06
2 47960  97.4062  16.7903 0001223 229.4344 105.3517 16.52337528    02
My probably last image from RS15S:
2025-04-12 10:38 at 160 km
well done, the signal was weak here.
There was a miscalculation due to the data in the previous one, this one should be more accurate:
Orbicraft-Zorkiy
1 47960U 21022AE  25102.44297445  .00000000  00000-0  46855-3 0    06
2 47960  97.4062  17.5104 0001223 229.4344 185.1678 16.48082326    06
It’s been very accurate for me.
@dl7ndr what was the elevation of the pass? If it was too low (under 20 degrees) then it wasn’t that bad :slight_smile:
Yeah @HS318, same here. Just about heard something in the noise but not enough to get any decode, max elev was only about 15deg. Probably no more opportunities for this one.
It was already below 10°.
Time is UTC + 02:00
One more update from observation over Hawaii:
Orbicraft-Zorkiy
1 47960U 21022AE  25102.46033348  .00000000  00000-0  39386-3 0    09
2 47960  97.4062  17.5227 0001223 120.1572  37.3955 16.49031468    00
Probably one of the last TLE updates:
Orbicraft-Zorkiy
1 47960U 21022AE  25102.50328010  .00000000  00000-0  32309-3 0    05
2 47960  97.4062  17.6791 0004803 125.8302 287.5925 16.60812534    07
With more than 16.5k of observations in Network and more than 93k frames from Network and 3rd party observations, Orbicraft Zorkiy is now re-entered!
Last transmissions were received by:
Last signal around 2025-04-12 12:06:40 UTC visible in:
This satellite served well with the strong signals. I used this satellite to demonstrate tracking and telemetry reception to students. Sent reports of the messages for the diploma but have not recieved antthing so far.
73, VU2JEK, Nitin
Has anyone received their diploma yet?
Jomjom79
No response since my emails from April 9th and 13th.
https://r4uab.ru/2025/09/03/malyj-kosmicheskij-apparat-orbicraft-zorkiy-rs15s/
Farewell diploma received :slight_smile:
Jomjom79
Got now also a diploma for receiving farewell messages, telemetry and SSTV.
My submission for the reception of the last (“golden”) beacon is still unanswered.
