RPi + gPredict + RTL-SDR
Hi all,
I’ve been researching a bit into adding a SDR to my gPredict installation, specifically the RTL-SDR. I’ve come across SDR# (SDRSharp), but as far as I’m aware, it is a Windows based tweak, whilst the RPI is running RPi OS (Linux).
Is there a method to getting this working?
Hello, not that I’ve seen… Here is a link to the all the RTL-SDR software that you maybe able to utilize and see what works for your needs. Listed with them are the OS that’s compatible for each.
https://www.rtl-sdr.com/big-list-rtl-sdr-supported-software/
There’s a bit of info on running gpredict and gqrx and getting frequency control from gpredict to gqrx so it tracks doppler properly.
You should get all info needed from these two:
https://gqrx.dk/doc/remote-control
http://www.ne.jp/asahi/hamradio/je9pel/gqrxgpre.htm
Thank you for all the info.
I set up GQRX, and used gPredict to control it via localhost.
Thanks for all the assistance!
Maybe this is also helpful Unix TLM decoding | Amateur Radio – PEØSAT
The best way Ive found is to install SDR++. It has a rigctl server near the bottom of the left column. The default settings work great all you have to do is tick all 3 boxes Tuning, Recording, and Listen on Startup then click Start. Ive enclosed a pic to show the configuration in GPREDICT.
