Hello all, I am attempting to get my RPi set up for SatNOGS.
When I run sudo satnogs-setup and apply my settings, it gives an error message at the “Updating APT cache…” step (error message shown below)
I think this has to do with the Buster-to-Bullseye transition. Unfortunately now the setup command does not work
Any help would be appreciated. Thank you for your time.
Reading package lists... Done
E: Repository 'http://raspbian.raspberrypi.org/raspbian buster InRelease' changed its 'Suite' value from 'stable' to 'oldstable'
N: This must be accepted explicitly before updates for this repository can be applied. See apt-secure(8) manpage for details.
E: Repository 'http://archive.raspberrypi.org/debian buster InRelease' changed its 'Suite' value from 'testing' to 'oldstable'
edit: @fredy: +1 for the much more concise answer!
We missed to vote who will answer, lol. I missed to check the thread / didn’t get a notification whether there are new posts before sending my message.
So, the following is essentially a duplicate of the previous message now.
Correct, the SatNOGS image continues to be on Debian Buster until a migration path for existing stations to Debian Bullseye was developed (which will happen eventually, but isn’t done yet).
Until then, the following command has to be run as a workaround once (tracked in satnogs-client-ansible#96):
sudo apt-get update --allow-releaseinfo-change
There might be a second workaround needed if you see the error described in satnogs-client-ansible#94. It can be fixed by the following command:
Thank you for this advise!
I had the same problems installing the last days the SatNOGS Client for the first time on my new RPi 4.
Applying the two work arounds allowed to start it up.
pi@raspberrypi:~ $ systemctl status satnogs-client
reports:
● satnogs-client.service - SatNOGS client
Active: active (running) since Sun 2022-01-16 15:36:35 GMT; 434ms ago
Main PID: 886 (satnogs-client)
Tasks: 1 (limit: 4915)
└─886 /var/lib/satnogs/bin/python3 /var/lib/satnogs/bin/satnogs-client
Jan 16 15:36:35 raspberrypi systemd[1]: Started SatNOGS client.
However, I still have trouble to see the station on the network - but that must be another problem.
