Rotor hardware?
Hello, I am considering building a rotor controller, with azimuth
and elevation for satellite work.
I do have a radio amateur license.
It will perhaps be built as a stationary or mobile unit, it depends on
what the home owner’s board say…
I think I will be using K3NG software.
I hope this will be implemented, as its very usable for those who run a
mobile set https://github.com/k3ng/k3ng_rotator_controller/issues/78
I want to use:
1x Raspberry Pi 3 Model B with Raspberry Pi Touch Screen 7" as a option,
hopefully with “level compensation” as mentioned in K3NG rotor controller issue 78.
1X Differential I2C Bus Extender (PCA9615)
1X 6 meters long shielded Ethernet cable.
For powering the steppers or DC motors:
1X DC bias injector
In remote box:
All these communicates over the I2C bus:
2X PicoBorg Reverse - Dual 5A Motor Controller ( these needs
implementation of stepper motor control in K3NG, related issue is #77
on K3NG rotor controller github )
1X DC bias extractor
1x Ozzmaker BerryGPS-IMU V3 for position, azimuth and magnetic North
with tilt compensated compass.
1X Adafruit LSM6DS33 + LIS3MDL - 9 DoF IMU with Accel / Gyro / Mag for
Elevation sensing.
1:60 worm drives with PWM controlled DC or stepper motors. 1:60 worm
drives nodes not need any brakes.
RF chokes on every cable, multiple turns.
PCB’s for DC bias stuff: https://github.com/Supermagnum/Mjollnir
So, Any comments or suggestions ?
