Hi. Im big problem no link good. I dont for what. Please help!!
$ rotctld -m 604 -r /dev/ttyACM0 -t 4533 -vvvvv
rotctld, Hamlib 4.0
Report bugs to hamlib-developer@lists.sourceforge.net
rot_init called
initrots4_gs232a called
rot_register (601)
rot_register (609)
rot_register (610)
rot_register (602)
rot_register (603)
rot_register (611)
rot_register (612)
rot_register (604)
rot_register (605)
rot_register (606)
rot_register (607)
rot_register (608)
set_conf: called
rot_open called
serial_open called
serial_setup called
serial_setup: tcgetattr
serial_setup: cfmakeraw
serial_setup: cfsetispeed=9600,0x000d
serial_setup: cfsetospeed=9600,0x000d
serial_setup: data_bits=8
serial_setup: parity=0
serial_setup: tcsetattr TCSANOW
serial_flush called
tcflush
Opened rot model 604, ‘GS232/F1TE Tracker’
Backend version: 20200424.0, Status: Beta
Connection opened from localhost:57640
rotctl(d): p ‘’ ‘’ ‘’ ‘’
rot_get_position called
rotctl_parse: NETROTCTL_RET -11
rotctl(d): P ‘98,52’ ‘10,75’ ‘’ ‘’
rot_set_position called az=98.52 el=10.75
rot_set_position: south_zero=0
gs232_rot_set_position called: 98.519997 10.750000
write_block called
write_block(): TX 9 bytes
0000 57 30 39 39 20 30 31 31 0d W099 011.
rotctl_parse: NETROTCTL_RET 0
rotctl(d): S ‘’ ‘’ ‘’ ‘’
rot_stop called
Connection closed from localhost:57640
Connection opened from localhost:57642
rotctl(d): P ‘106,90’ ‘11,69’ ‘’ ‘’
rot_set_position called az=106.90 el=11.69
gs232_rot_set_position called: 106.900002 11.690000
write_block called
0000 57 31 30 37 20 30 31 32 0d W107 012.
rot_stop called
Connection closed from localhost:57642
If put -m 601, 602, o 603 tild interface but -m 604 error up.
Julio
LW2DYB
