I’m a brand new Gpredict user trying to get a homebrew stepper Az/El rotor to work with a controller running Easycomm. I can issue Az and El commands and receive back current rotor positions using a terminal program, but not with Gpredict.
Running Windows 10, Gpredict 2.2.1, Hamlib w64-4.7.0
I can execute rotcld.exe and get the following status. But as soon as I attempt to move the rotor, the error appears and Gpredict crashes.
Thanks in advance for any suggestions.
Randy WB0VHB
rot_init called
initrots4_easycomm called
rot_register (201)
rot_register (202)
rot_register (204)
rot_open called
serial_open: serial port COM4 is OK
serial_open: COM4
serial_setup: tcgetattr
serial_setup: cfsetispeed=9600,0x000d
serial_setup: cfsetospeed=9600,0x000d
serial_setup: data_bits=8
serial_setup: stopbits=1
serial_setup: parity=0
serial_setup: Handshake=None
serial_setup: tcsetattr TCSANOW
ser_set_dtr: DTR=0
ser_set_rts: RTS=0
Opened rot model 202, ‘EasycommII’
Backend version: 20231218.0, Status: Stable
Connection opened from ::ffff:127.0.0.1:58007
rotctl(d): p ‘’ ‘’ ‘’ ‘’
rot_get_position called
easycomm_rot_get_position called
easycomm_transaction called: AZ
write_block(): TX 3 bytes
0000 41 5a 0a AZ.
read_string_generic called, rxmax=32 direct=1, expected_len=1
read_string_generic(): Timed out 0.201 seconds after 0 chars, direct=1
easycomm_transaction read_string failed with status -5:Unknown error
easycomm_rot_get_position got error: -5
rotctl_parse: NETROTCTL_RET -5
